We value your privacy.
>I took the time to look at my wood pile this morning. My pile is in the shade about 80% of the day with indirect sun the late afternoon. I found a number of log sections starting to crack from the edges inward. All these had two coats of woodcrafts green tree sealer (made by anchorseal I think). I put a third coat of sealer on to hopefully stop them.
We have been running about 10 degrees hoter than normal with some very hot sun so I am guessing this is what is causing it. I know mwny areas are doing the same. You may want to take a look at your wood pile also.
It's my understanding that no amount of anchorseal will prevent logs from splitting, just slow down the drying and perhaps minimizing the cracking. Moisture will still escape through the coating, and when it dries it will shrink, and if the stresses are high enough, split.
Coating just the ends of a log will minimize the end checking, but not prevent the log spltting down the length.
Sealing the wood even more, e.g., seal completely in plastic, should slow the drying even more but at the risk of fungus.
I have had more luck with turning blanks by coating the entire outside with anchorseal. I belive this causes the moisture to be more evenly distributed since the very outside layers dry more slowly and the moisture deep inside has more time to move outward before the outside shrinks too much and cracks. Of course, the final outcome depends a lot on the tangential/radial shrinkage ratio of the specific wood species. I think the best thing for some is to just use it up fast! If it's not possible to at least rough turn, I believe the next best thing is to section it into smaller pieces (turning blanks) and seal those all the way around.
The book "Understanding Wood" by R. Bruce Hoadley has some interesting info on water, drying, and shrinkage.
Right now in my new digs I don't have a good place to store wood. It just sits in the driveway in direct sun. The only way I can save much of it is to split it at the heart. coat the ends with anchor seal and leave the logs longer than I will ever need for making things. This way I can cut off the ends that split. I still throw away a lot. When a log starts to crack badly I cut them up into 3x3 or 4x4 squares to slavage that wood for smaller spindle projects or boxes.
>Couple of months back I cut up 2 maple logs that I had left lying in the leaves for 2 years to induce spalting. They were looking good so I cut them into appropriate sizes and anchorsealed the ends with 2 coats and stored in the garage. I had 14 blanks ready to be roughed into bowls and everyone of them cracked on the ends and became useless for bowls. I will now saw them into small boards for other projects.
Around here I have to leave at least 6" on each end or I lose the bowl. I prefer to leave the logs long but it's so difficult to get them from the field to my house if they are large so I have to cut them shorter than I want.
>I have a snake in mine. Saw his tail slither under the logs when I was getting some tuff to take to Dick Saturday. That's why he didn't get any maple...I couldn't tell what kind of snake it was and decided not to go rooting around with my bare hands anymore. LOL Good thing I didn't see it before I had gotten the Cherry and Mulberry or he wouldn't have gotten any wood at all.
>It has always been my experience that wood stored in the round has little chance of survival without cracking because the radial shrinkage is always greater than tengential, and something has to give as the wood dries. Sealing only slows the drying rate; it doesn't stop it.
Round wood will survive if it is totally wrapped in plastic, and that can induce spalting; but can also lead to problems with rot and mildew stain if not monitored carefully.
Log sections that have been split in half to remove the pith has a better chance of survival when everything except the bark is coated.
Wood that is cut into a lathe-ready bowl blank and totally covered with the sealer has the best chance of survival without cracking.
And there will always be some wood that will self destruct no matter what we do to it.
>While it is good to coat the ends, and to leave the bark, although it may harbor more insects than debarking. When I notice the checks starting, I set up a sprinkler to KEEP it wet. Notice, I said keep it wet. It is not a good idea to re-wet dry wood. That will cause honeycombing, but if it is just drying on the outside, and the inside is still wet, this will close the superficial cracks from drying on the outside while the inside is still wet. That outside is already waste anyway.
I'm sure you know the difference and this is just a typo, but in the interest of accuracy it's the other way around: the tangential shrinkage is always greater than the radial. (At least in all woods I know about)
