New WoodChat!
jet 1442vs lathe
jet 1442vs lathe
jet 1442vs lathe
Dave Anderson
>I have been turning for about 6 months on a Jet mini (which I really like) and I am starting to look for a larger lathe. I have not read much positive about the Delta lathes. I have not been impressed with the Delta tools that I do own. The Powermatic 3520 or any lathe over about $1200. is out budget. I am looking at the Jet 1442vs or the Nova 3000 (not dvr). I would appreciate any info on these lathes.
Thanks in advance
Dave Anderson In the PacNW
Re: jet 1442vs lathe
Oscar
>I have a 1442 that I'm pleased with. I was in the same situation as you had a Jet mini and wanted to up grade to a larger lathe. I feel the outboard rest extension is a joke. It broke the second time I used it. The lathe could be heavier, build yourself a ballast box for it. Buy the biggest, heaviest lathe that is within your budget. Oscar
Jim Eddy
>I compared the Jet 1442 to the Nova 3000. I bought the Jet for these reasons:
Longer and heavier ways
Variable speed (mechanical)
Cast Iron legs included
100 bucks less.
CJ
>I also upgraded from a Jet Mini to a Jet 1442 almost 2 years ago. I have no regrets, and happily recommend it to anyone.
nelson brooks
>The basic Nova 3000 is no longer avaiable only the DVR, unless you find one used you would have to go with DVR, I agree the 1442 is a better lathe because of the sliding headstock, good luck with getting a bigger lathe.
>When I went looking for a grand piano years ago I went with the advice: "buy the next one up from the one you think you can afford and you won't be sorry." I did (actually, I bought from several models up) and I have never been sorry. I think the same holds true with lathes.
JKJ in East TN
Bruce Wiseman
>Hi,
Nelson is right the Nova 300 is no longer being made, however there are many still in the retail pipe line and you should be able to get a close out price. The 3000 requires a manual i.e. move the belt to change speeds. The lowest speed is much lower than the Jet. Changing the belt would be infinately easer than the 1442 and SOME 1442's are very hard on the belts. You can change out the motor on the Nova to a variable speed and / or upgrade it to a dvr. With the outriger attachment you can turn 19 inches. I have one and like it a lot. Email me if you want more info.
Good Luck.
Bruce
gil
>I have a 1442 that I bought over a year ago. Very happy with it. Try to predict the future and decide how much bigger you will want to turn. If the answer is "over 14 inches" then you will have problems with this one. Get something bigger, or the same size with EVS control. I say this because you can turn the head around for something larger than 14". You will then, of course, lose your tailstock. Also, unless the log (which is over 14") is balanced to start with, the 1442 will want to dance at the slowest speed setting.
tek-Brunswick, Ohio
>I have a used Nova 3000 that I picked up about year ago. Mine has a 1 HP DC variable speed motor. I'm very happy with it. I like the swiveling headstock. I usually swivel it 45 degrees to work on the inside of boxes and bowls.
Keep checking the classified ads used ones show up. Usually because the owner wants to upgrade to a DVR. I plan on keeping mine for quite a while. It sure is an improvement over the Craftsman Monotube lathe I started on.
Tom
dick mcneill
>I own & use a Jet 1442. It has some significant problems: (1) its' slowest speed is 450 rpm (too fast for many applications)(2) it has no reverse rotation (3) the speed adjustment arm will block your access to the turning when working from behind the headstock. I wish I had spent the extra money & bought a Jet 1642.
Dave Anderson in the PacNW
>Thanks to all. It looks like I will get the Jet in the near furture, unless the turning Gods have other plans.
Dave in the PacNW
Eric
>Word on the street is that Woodcraft will offer this lathe on sale for $765 on July 28. I called my local and they wouldn't confirm, but said that it was "possible". Keep your eyes open for this sale!
Eric
