New WoodChat!
bocote toxicity?
bocote toxicity?
bocote toxicity?
GaryG in MD
>I've been looking at wood toxicity tables to determine what woods I will not turn. I haven't been able to find out much about bocote. It's not in most tables.
I've found that if you've been sensitized to other woods like cocobola, you'll be sensitive to bocote. Some other bad reactions have been noted, but I can't get a good feeling for how common or uncommon these are or at what level of intensity. I'm not sure if it's just a dust problem, or if the wood itself is a sensitizer from just handling it.
I have a lot of allergies and don't want to take unnecessary risks, but bocote looks awfully nice, and I'd like to turn it if I could, within reason.
I'd like to hear what you all know about bocote toxicity. Is it, like cocobola, just better avoided, or, if I don't turn cocobola and rosewoods, is it ok to take a shot at bocote?
Thanks for your thoughts.
Gary
Re: bocote toxicity?
>I have allergies also. They really shouldn't matter with proper precautions. Use a respirator (Trend or whatever) or a really good dustmask and a dust collector. My setup has a dust hood at spindle height. The dust collector is turned on whenever I turn. I always wear a dust mask or a 1/2 face respirator when turning, especially when sanding.
Richard Allen
Richard Allen
>Hi Gary
I have developed an alergy to Bocote. I have no other wood alergies.
For me the alergy was an avalanche event (which is usual for alergies I am told). I worked Bocote without any ill effect. I was making a coffie table which involved a LOT of sanding. It was a warm few days I was woring with the wood. Beyond an effective dust mask I had no protection. On the second day I had a slight rash. Not much to worry about (I thought). After the third day the rash was a little worse. By the morning of the forth day I was experinceing hives that made my life hell for the next two weeks. At that time I didn't know what the cause of the alergic reaction was. Over the next couple of months I discovered that it was Bocote I was alergic to. I tried turning a pen a year latter. With that small exposure I again developed a rash.
I studied the subject and and came to the following understanding:
When working with exotic wood cover up. That is wear long sleeve shirts, long pants...
Work in an environment wehre you won't sweat. The dust from sanding will mix with sweat and form a concentrate which will acelerate the alergic reaction.
Limit your exposure. This is to say, plan your exposure to short duration. Don't work an exotic wood without cleaning yourself up right away. If you are making three bowls, One maple, one cherry and one bocote then do the bocote last so that the length of time that you are exposed to the Bocote is short. Take a shower as soon as you can after turing the wood.
At least this is what I now do.
Good luck
Richard
GaryG in MD
>Hi Rick,
Very interesting. I kind of thought it might be one of those, but the literature is a little sparce. Thanks for all the good info. I'll definitely take extreme care when I mess with it. Thanks.
Happy 4th,
Gary
GaryG in MD
>JL, It's pretty clear we don't want to be breathing dust of any kind; that's a given. The problem with the exotics is that many of them are sources of contact dermatitis or worse. I don't normally turn with gloves on, particularly not rubber gloves. I'm hoping to find out what "interesting" woods I can expect to turn without getting dressed up like an astronaut (see Verne's post above) and spending more time vacuuming than turning. Happy 4th, Gary
>A couple of suggestions then. You can go the tyvek coverall route - they run about $6 or so each. You could go the "oversleeve" route and wear these with gloves.
I have a turner's smock. You could wear one of these with gloves and tape the sleeves.
These would all minimize contact exposure. My $0.02.
GaryG in MD
>Yup, good ideas. No skin! Thanks. ...Gary
