Belt Replacement
Doug Bartos is Md
>I have a Fisch mini lathe and the belt is toasted. Does anyone have any recommendations on where to get a replacement.
Thanks,
Doug
Belt Replacement
Doug Bartos is Md
Thanks,
Doug
Do you know the size ?
Fred in NC
>Is it a serpentine belt (has ridges in it) ?
Re: Do you know the size ?
Doug Bartos is Md
>Hi Fred,
Yes, it has ridges. I'm pretty sure that it is the same size as the Delta Midi.
Doug
Re: Do you know the size ? *LINK*
Fred in NC
>I buy my belts from Aarubco Rubber. They are very inexpensive, have good service, and don't gouge you on the shipping. Look at any numbers on the old belt. Most minis use J-section 3 rib belts. Then you need to know the circumference in inches. You cannot order from the web site, have to call them on the phone. Since they are so cheap there I would order a couple of them. Just a satisfied customer.
http://www.aarubcorubber.com
Doug Bartos is Md
>Thanks Fred, I'll call them on Tuesday.
Doug
