New WoodChat!
ADVERTISE HERE - FREE TRIAL
Dust collector w Magnetic base
Ben Aragon
>Hi all,
Dust collector with Mag base.
I thought I’d post this incase it might help anyone. I needed a dust collector for sanding and had seen some commercial units so thought I would build one. I used some standard 4” duct work from Lowes, 1” square tubing I had and a magnetic base from Enco. The tubing was cut and drilled for 5/16-24 thread, through holes on one piece and tapped for the other. I loosen the socket head screws to make adjustments. The magnetic base has an ON/OFF switch, which makes it easy to move anywhere on the lathe. This is also nice when I’m burning or power carving, I have a thick piece of sheet metal 12”x12” I place on the workbench next to me and stick the mag base dust collector right there. Comments welcome.
Best Wishes,
Ben
Re: Dust collector w Magnetic base
Better look
Ben Aragon
Magnetic Base
Ben Aragon
Fred in NC
>Ben, that is a good idea. I use these magnetic bases for several purposes, and they work very well.
Dennis Thomas
>Ben,
Great idea using the Magnetic Base! Did you get the 110 or 160 pound pull base from Enco?
Thanks
Dennis
Ben Aragon
>Dennis,
I'm not sure I've had them a long time but I would get the 160lb, the black hose is a little heavy.
Ben
