live center
william wray
>Need advice about live centers, new at woodturning,
what to look for, also about chucks and face plates.
thanks...
william
live center
william wray
thanks...
william
Re: live center
>You said: "Need advice about live centers, new at woodturning, what to look for, also about chucks and face plates."
Depends on what you want to do. I have used a number of "live centers". Typically one comes with your lathe. The Oneway live center set works quite nicely also. It is pricey though.
For drive centers, one of the better aftermarket ones, IMO, is the Sorby Stebcentre. I really like the 7/8" and 1/2" for spindle turning.
For chucks, everyone has their favorites. I like the Oneway Talon Scroll Chuck and the Oneway Stronghold (I have one of each). I have used a Nova chuck (don't remember which one) and it worked great.
Faceplates I don't use much, so I have no opinion.
Re: live center
john Lucas
>William
I had a Nova live center for many years and like it very much. I don't do a lot of heavy work however. If I did I would look at the Oneway. I also like the Delta live center. It's cheap but holds up well.
I like the standard 4 prong drive center better than anything. I have 3/4" that I use mostly and a 1 1/4 that I use for big bowls. I'm drooling over the big screw on drive centers from www.bestwoodtools.com but haven't been able to part with the cash.
I'm real partial to my Vicmarc 120 chuck but I would be just as happy with a Oneway Talon I think. If you need a chuck and money is tight look at the Grizzly copy of the vicmarc. It's a really nice chuck for $89.
Re: Thought about a drive center for your chuck?
Al Crandall --NE of Indy--
>HI JOhn. I use a 2" drive center from bestwoodtools in my Talon chuck, and my buddy Duane Leach uses one in his Vicmark chuck. They are brand specific, but we both love our own. Might be a few bucks cheaper than the dedicated screw on ones.
john Lucas
>Al
I've been looking at those also. I like the idea of not having to pull the chuck off when turning bowls. When I get the money I'll probably either look harder of flip a coin.
Re: live center
Arch
>William,
If you don't have a tail center or only the common 60 deg. cone tail center, alive or dead, I suggest you consider a cupped live tail center. If you have a cupped dead tail center use it as a headstock clutch drive for spindles that slips to prevent damage from catches. The rim of a cupped tail center should be sharp and shallow so the surface of the center betweeen rim & point registers against the wood. IOW, the rim prevents splitting the wood, the surface drives the wood and the point centers it.
Hope this isn't a confusing version of "Who's on first?" :)
Arch
