New WoodChat!
THE WOODRAT IS BACK!
Question for PM 3520 owners
Carole in VA
>(and vertically challenged turners.) I notice that the Powermatic 3520A has a spindle to floor distance of 44". Is the height adjustable on this and other full size lathes? I am about 5'5" and I have my Mini at about 39". 44" would be really uncomfortable for me and I have no doubt that if I had to stand on a 5" platform, I would eventually break my neck!
Re: Question for PM 3520 owners
RonZ
>I have the same problem and I'm the same height. I was unaware of the problem and while turning on my VL300 I developed trigger finger, tennis [turner's] elbow and shoulder problems. I built a stand but like you said but it's cumbersome, takes up precious floor space and I fear that I'll trip and see you next fall. My flooring is layered cement, sand, cement and stone tiles. I plan on cutting out some of the floor layers and lowering the lathe.
Oh dear! :((
Carole in VA
>I can't cut out any of my cement slab. :( Certainly the manufacturers must realize that this can be a problem!
Re: Oh dear! :((
RonZ
>Well, if I knew then what I know now, I probably would have got the VL200. Perhaps some manufactureres think that the shorter you are, the less swing you need over the bed. ;)
There are a few manufacturers that adress this but not too many.
What I mean by cutting the cement is using a stone cutter to cut out the exact size need for the feet of my lathe. I suppose you could throw back in more cement over the sunken legs and this would also contribute to more stability. In your case, it would be cutting out four squares, one for each leg. Not too big of a deal.
Jim Putnam
>Carole,
I'm about your height and have been turning on a 3520 for a couple of years using a 2" platform. My Delta MIDI is about 41 3/4" to the centers and my 3520 is about 44 3/4" with the adjustable pads removed and the cast iron leg resting on the floor, so I'm used to the lathe being a little taller than yours.
My platform is 7/16" waferboard with a 2x4 frame. The overall dimensions are 28" x 60" and it has a couple of 6" notches for the legs on the lathe side so that it slides under the lathe a little. It's fairly light and moves up and out of the way easily for cleanup. Tripping or inadvertantly stepping off the edge has not been a problem, but I suppose that if I cleaned up my shop and got the other stuff off the floor I'd notice the difference.
I haven't turned off the end yet so am not sure what I'll need to do for that. My platform was a quick project done as an experiment and has worked well enough to keep me from making a better one. If I upgrade it, I may make it a little higher, put a ramp around it and maybe use a rubber pad to give some cushion and traction. I really like the 3520 and find the platform a very small penalty for using it.
Carole in VA
>Jim, the specs for the 3520A state 44"(adjustable). How much can you adjust the height, or is that something new?
john Lucas
>Carol I'm 5'6" and it just right. It actually is a hair high, I find it better without the levelers but right now I have them on because I haven't found a good place to put the lathe. Since I only need about 3/4" of height I'll probably look at a plywood floor built up out of panels around the lathe. I figure I'll bevel the edges and paint them so I'll hopefully know to step over them.
Dick Hines
Dick Hines
>How about some 1970's platfrom shoes?
One od the guys in our club has the "big" PM 2442 and he also is not tall. He put a duck board platform in front of his lathe. So far he has not manged to fall off.
I had to go the other way. I rased my lathe to 50".
Sounds like you are going to make te jump.
Mark Kauder, Phenix City, AL
>Carol,
As a shameless shill for Vega, will mention that the Vega 2600 (formerly the 2400) will adjust spindle height from 37"-44". It will handle up to 26" bowls and spindles from 4"-17". It costs almost exactly the same as the PM3520.
Mark
Carole in VA
>"How about some 1970's platform shoes?"
Now I know from past experience that I would definitely fall off those things! LOL
Have fun on I-64 tomorrow morning. See you at the show.
Jim Putnam
>I just went out and double checked my lathe center height by putting a steb center in the tailstock and measuring through the bed to the floor - 44 3/8". I was a little off before.
My lathe came with some adjustable threaded feet that screw in to the base of each leg. I couldn't find the ones that came with my lathe, but I recall that they have a 2 to 2 1/2" threaded section that screws into the bottom of each leg of the lathe and that would account for the claim of adjustability. I took mine off because when adjusted all the way down the thickness of the pad on the end of the threaded portion would still take the lathe up another 1/2" or so. These adjust like those on appliances and provide an adjustable height from just under 45" to something like 47". Taking them off completely gives the lowest possible adjustment - 44 3/8" on my machine. I'm not sure if it makes a difference, but my lathe is a newer Taiwan made machine.
Dick Hines
Dick Hines
>Thatks. I just saw in the paper that I64 in Tidewater is the second worse bottle neck in the country.
Going to leave early. Going should not be so bad, how comming back is another thing.
There She Goes Everybody! : )
Jennifer@Indy.USA
>Carole,
Do I sense that you've already gotten the itch for a bigger lathe? Nawwww....couldn't be :)
How did everybody here watching you exlpore and zoom up the learning curve know this was bound to happen?
I can't wait to hear what you decide on. You deserve it Carole. Move up and don't ever look back. You won't regret it a bit. My advice...don't ever get rid of the baby Jet. I use mine all the time.
Go Carole Go!
Jen :)
Re: There She Goes Everybody! : )
Carole in VA
>Soon, maybe. My Mom gave me a tidy little (big?) sum for my birthday, so I went to the bank and opened a savings account as a lathe fund. That way I won't dribble it away on other stuff. Moms are soooo wonderful! It's time to do some serious comparison shopping! :))
Rick Allen
>Naturaly Oneway offers various leg sets for ther big lathes and the 1640 has adjustable legs which cover spindle heights of which adjust from 42 - 46.
You can always make you own stand for the powermatic. Nothing says you HAVE to use the legs which come with the lathe. If you like a 39" spindle height then make a stand that will put the lathe at that height.
Good Luck
Richard
Jim Putnam
>Excellent idea Rick.(Thanks!) It didn't occur to me and I have a welder in my shop and have made all of my mobile bases.
Now you've got me thinking about making a set of legs, maybe a steel cabinet with dust collection built in, and maybe a little platform that aligns with the bed and swings aside for getting the tailstock out of the way without lifting it up and down (for when I'm older and possibly smarter)and....
