New WoodChat!
Wood lathe stand
Wood lathe stand
Wood lathe stand
Kudzu
>I saved an old cabinet out of bathroom. It's been sitting in the barn waiting to be used for something worthwhile. I finally had some time to plan my stand for my bowl lathe and got to thinking about this cabinet so I brought it into the shop. It's nearly perfect height for the lathe.
Don't ask about the burnt spot :-)
Since it is fairly long I decide to see about just putting my wet grinder and standard grinder on here too. I think there is enough room so I could put a polisher on there too. I think the lathe works better turned 90 degrees to what is shown. I probably will need to keep the grinders covered to keep dust out. Otherwise this looks workable. Has to have a coat of paint to hide the UGLY yellow!
My thinking is to reinforce the cabinet by adding a layer of 1/2 ply on the sides and back. Adding a couple of braces across the top from the face frames to the back. Then filling it with sand bags for ballast. That would still leave me with lots of storage inside. If I swap ends with everything that would also place the one drawer under the lathe to hold the chuck jaws and odds and ends.
Re: Wood lathe stand
>Hey, I thought I was the only one with old cabinets stored in the barn!
I'd worry that lathe use might eventually shake a cabinet apart unless it was very well reinforced. Most are put together with staples and don't have to be all that strong since they are fastened to the wall. Perhaps some 3/4" plywood webs inside along with the bracing? Diagonal bracing would be better than just bracing on the top. I'd probably also use 3/4" ply on sides and back instead of 1/2" A continuous thick top might also help - two layers of 3/4" ply or 2x lumber?
If you have room, how about a separate stand made from heavy timber would leave that cabinet as a great base for the worktable/sharpening station. You could make a really sturdy lathe base from 4x6 and 2x12 bolted together.
If you can find it, a piece of old bowling alley floor makes a sturdy top! I made a workbench from some of this and an old kitchen cabinet.
JKJ in East TN
Dave Fuqua
>Even if you paint it, can you keep the burn spot? Adds character ;) and probably has a 'good' story behind it. . .
Kudzu
>We are more or less on the same line of thinking. The reason I was thinking 1/2 ply is the carcass is all ready 1/2" plywood. The back is just a 1/4" ply so it really needs a bit more strength but not really 3/4" ply.
It does need at least one more brace running from the face frame to the back. I am going to attach the top to these braces so that all of the cabinet is tied together as one piece.. This should add a lot of rigidity to it. As for the top I think once you screw down a piece of 3/4 plywood to the braces it's not going anywhere. If needed at the lathe end I couldt add a couple of stiffeners under it. Plus an an oversized apron running around the lip, this puppy should be very stout!
I will have a variable speed on this lathe and I expect to bandsaw most of the blanks to somewhere near round. So I won't be using extremely out of balance blanks at high speeds. I was going to build a really stout stand but the more I thought about the intended use and looking at the cabinet I don't think I really need to. But that is subject to change too. :-) Using it for a dedicated grinder/sharpening/ploishing station has crossed my mind and I do have the space for it.
Kudzu
>No good story. Just tired to burn down our cabin. No damage was done other than what you see but I don't need any reminders. I remember it well!
Fred
>Wow Kidzu I didn't think anyone had one of thouse old wet
grinders anymore. Have you ever trued the wheel on it, and if so how.
Fred
Reminds me of the time my older sister tried to repair the antenna on the back of our family table radio using a propane torch and some solder. Or the time we "experimented" with the coal furnace by throwing in handfulls of coal dust. Or the science experiment in the bedroom that got out of control and set the curtains on fire during the emergency procedure of "throw it out the window, hurry!". It's a wonder the poor house survived.
JKJ in East TN
Kudzu
>I just got this a few weeks ago. Stumbled across it on Ebay, listed badly so I got it cheap. I have not tried it yet.Once I get the cabinet done I will mount it and give it a spin.
