New WoodChat!
Jet mini VS problem
Jet mini VS problem
Jet mini VS problem
john Lucas
>As some of you know I bought a Jet Mini return item from a local junk dealer. It has no torque. Everything looks like it works properly. All belts tight, set screw tight etc. You can stop the handwheel easily by hand at any belt and speed setting. There is 50 to 100 volts DC out as I vary the speed. What I noticed last night was the motor is rated for 192volts. Do I have a european model with a 110 plug on it. I think most DC motors I've dealt with have a rating of around 90 volts. Does that make sense. I'm afraid to plug it into 220 until I find out more info.
Re: Jet mini VS problem
Re: Go to the Source
>John,
A toll free call to JET should answer that and derivative question quickly.
Eaglesc
>MOdel and serial# "might" even get you a free motor.
Is it possible the motor has already been switched for some reason?
Fred in NC
>Eagle, it is possible that you are on the right track !!
Some DC controllers have internal switches to select input voltage, and min/max torque and speed. The switches are in the circuit board itself, so you don't see them. This allows use of the board in different markets. The downside is that very often these internal switches are not clearly marked !! "S2" does not tell much ....
A call to Jet with all the info might solve the problem.
Fred Bearman
>For whatever help this offers, I just went out to the shop and looked at the motor on my JET VS Mini and the specifications label lists the voltage on mine as 162 volts DC. This was purchased in the US for US use, and is plugged into 120 VAC. Hope this helps to narrow things down - I have had good success e-mailing JET's support people in the past. Good luck.
Fred Bearman
Port Huron, Michigan
