New WoodChat!
THE WOODRAT IS BACK!
New jaws - or new chuck?
GeeSeaWhy
>Does anyone know of a set of jaws for either the Supernova or the Axminster Precision that will close comfortably on a tenon in the 65-75mm (2.5-3") range? In all the jaw sets I already have, none will go wider than 65mm except for the 100mm (4") Supernova jaws, which won't hold on anything under 80mm. Surely there must be something out there, but I can't find it.
Graeme
Re: New jaws - or new chuck?
John Trant (Baltimore/WashDC)
>You should be able to get a set of 75 mm jaws (3") for your Nova/SuperNova. I know WoodCraft sold them at one time but I am sure others do also.
John
Re: New jaws - or new chuck? *LINK*
CapeMayMike
>Axminster makes a full line of jaws and Craft Supplies carries most if not all. They also carry the various Nova jaws. See the link below:
CS Jaw selection
GeeSeaWhy
>Unfortunately, Teknatool built the 75mm jaws with much wider tops than the 50 and 100mm jaws. As a result, the outer diameter is between the 50 and 100 ranges but the inner diameter is almost identical to that of the 50mm jaws. And I very rarely use chucks in expansion mode.
Graeme
GeeSeaWhy
>The CS web site does not list capacities for any of the jaw sets, however. The catalog does, but some of their numbers are wrong. I ordered the Supernova Powergrip jaws from them on the basis of their stating that the jaw set would hold in compression mode down to 1-5/8". In fact, the Powergrip jaws have almost the same capacity as the 100mm jaws. The Axminster 4" dovetail jaws come closest to what I want, but I'm not sure I can trust the numbers given by CS.
Graeme
CapeMayMike
>Call 1-800-398-2743 and ask for Roger Durst. He's one of CS techs and a good guy, he'll steer you right.
GeeSeaWhy
>Thanks Mike,
I did call them to see if they could suggest any alternative before I returned the Powergrip jaws. The person I spoke to couldn't, but I don't remember his name. Maybe I'll try asking for Roger.
Graeme
Brad Vietje
Brad Vietje
>Graeme,
Will the multi-step jaws work ? They cover the sizes you need, but they are rather shallow, and the larger diameters might interfere with access to smaller workpieces.
I tried making my own jaws once (need about 35 mm dovetail), but was not at all happy with the results -- may try again someday.
Safe Spinning,
Brad Vietje
Thetford, VT
GeeSeaWhy
>Brad,
It does appear like the step jaws might do what I need. They certainly do cover the right size range. I hadn't really considered them because they seemed to be designed to hold a bowl by its finished foot - would they hold well enough if the bowl was only rough turned? I'll try to take a look at those the next time I'm in Woodcraft.
Graeme
Brad Vietje
Brad Vietje
>Graeme,
They have a 15 degree dovetail, which can work very well IF the foot is properly sized and shaped. It the dovetail varies much from 15 degres, it might be a weak hold.
Safe Spinning,
Brad Vietje
Thetford, VT
GeeSeaWhy
>Thanks Brad,
Sounds like the step jaws should meet my needs then - most of the bowl-type jaws I have are also dovetailed. So the step jaws are really for holding footed bowls, but only if you regularly make your foot dovetail-shaped? Or do they mean bowls with a tenon *and* a foot to get the bowl clear of the jaws? Why are manufacturers so poor at publishing detailed specs for their jaw sets?
Graeme
