Christmas ornament
Bobby
>A Christmas ornament that will be donated for a charity auction that the woodworking club I belong to supports.
Bobby
Christmas ornament
Bobby
Bobby
WOW! Sizes please.
Dave Smith, Longview, WA
Re: Christmas ornament
Jim Shaver - Oakville, Ontario
>That is Wonderful Bobby......a True Christmas treasure!
take care,
Jim
Very Nice.
john Lucas
Ruth Niles
>Very nice, Bobby.
How do you do the icicles or stems that they blend into the ornament so smoothly? I've never seen them done this way, usually they are obvious add ons.
Ruth
Detail
>Hi Bobby,
Is that a captured ring on the icicle as well, very nice again!
take care,
Jim
Fred in NC
>That is very nice! I am sure they will love it, and it will bring good money for a worthwhile cause. Great job!
john Lucas
>Bobby I make a lot of ornaments to give away to raise money for local groups. I'm always dissappointed by the money they raise. In our area (very rural Tennessee) ornaments just don't bring much money. I had one go as high as $40 once but usually around $25. My friends sell ornaments all the time for $30 to $60 but not around here. Hope yours is much more successful.
Bobby
>Thanks for all of the comments, I appreciate them. The ornament is 9" long and about 2" in dia. It's a little longer than I planned but I had trouble with the captive ring, it kept breaking. Ruth, I bevel the opening for the stem and then turn a tenon on the stem until I get a tight fit. I then put it in place with the tailstock holding pressure on it and turn it down till it's level with the body of the ornament and sand it. It usually comes out pretty good with a good match. I hope that explains it OK.
John, I hope they get a good price for the ornament also. Items like this usually don't sell for that much around here also, but I'm hoping that since it's for charity it does well.
Brad Vietje
>Very nice ornament, Bobby.
I also make a smooth-join variety (regarding Ruth's question). I turn and hollow the globe, and leave a small flat surrounding the opening, which is a short cylinder on the inside. I then carefully mate a roughed-out spindle piece so I get a good glue join on these two right angle surfaces. If the join is tight, you can then turn the ball and spindle together and cut right through the join to make a very smooth transition form one wood to the other. Spindle details are turned after the glue-up. The problem is that they have to be very flat and concentric with the lathe axis. If they're out of alignment (with the axis of the piece), the join will be crooked when you cut through it, which looks awful.
The other feature that no one but another turner will ever notice, is that you can spin the ornament by its two ends in your hands, and the entire thing runs true. It's a lot more work than gluing the pieces together when they are all complete (which could then be a little crooked and still look great), and John's right on about selling these. You'll only rarely get paid for all the work that goes into these -- a labor of love more than profit. The most I've gotten for one of these, 3 pieces turned as a unit, is $ 85.00 for a fairly large one (~3" by 9") turned from Cherry burl and maple, but that was at a high-end shop in a preppy $$$ college town.
The pic I'll try to attach shows a small ornament in progress; I left a small step in the maple, then cut through the join with the Rosewood. i often do these with no step at all.
Safe Spinning,
Brad Vietje
Thetford, VT
Ruth Niles
>Hi Brad,
Thanks for the picture and the process description. I have 2 questions:
1. What are you using in the tailstock to hold the end of the stem?
2. How do you do the top stem? Wait, I think I might know; you part off the ball/stem leaving a flat the same as the bottom, then mount the whole ornament back on the lathe and final turn the top stem. Am I right?
Ruth
Brad Vietje
>Hey Ruth,
Hope you see this -- we're getting a little buried with all the new threads...
I do one of 2 things. The ornament pictured is a 2-piece ornament (well, to be honest, it started out that way, and ended up being a 3-piece !) For 2-piece ornaments, I finish the spindle details, but don't quite part it off for stability. Then I shape a short spindle near the chuck from the same piece of wood as the globe, and when all is sanded and finished, I part off the tip of the spindle, support it with one hand while carefully and very lightly sand with 400, then apply the finish. Then I part off the chuck end.
For 3-piece ornaments, I turn the globe and drill all the way through it, leave a stem until the exposed end is completely shaped & finished, and the longer spindle is attached and roughly shaped. then I part down to a short stub at the other end, leaving a 1/8" tall hollow cylinder, then a second parting cut to separate it from the lathe. This cylinder gets glued into a prepared block of contrasting wood to make the short finial. Then the entire works is turned between centers so it runs true. a real pain, but for an exceptional gift or exceptional piece of wood, it seems worth it to me.
I need better photos (and a camera)... When i sell my house and can afford to replace my camera, I'll try to get some good shots of 2- and 3-piece ornaments in progress and finished -- hopefully well before Christmas ! I'll attach a rather clunky looking 2-piece from Padauk and Maple, then a pic that shows a few finished ornaments, including the one (now 3 pieces) pictured earlier.
Brad Vietje
>Here are a few finished -- some with smooth transitions from cutting through the glue join, and some have small steps. the 3-piece one was a save -- originally destined to be a 2-piece (all I made back about 21/2 years ago) -- I tried to change the shape of the globe, and cut through it, so I mounted another chunk of Rosewood, and made it work. I drill a 1/16" hole through the tip of the finial for mounting on a bent brass wire hook.
Ornaments pictured are Curly Maple and various Rosewoods; farthest one is Maple/Ebony. Roughly 2" in diameter by 3" to 5" tall. Sorry -- not a great photo, but best I have until I get a new camera.
Safe spinning,
Brad Vietje
Thetford, VT
Re: Tail center
Brad Vietje
>OOPS -- I forgot to answer the revolving center question... I use the inexpensive set from Craft Supplies with about 5 different tips (~ $45.00). I suspect it is the same as the Sorby, which costs more, and is probably more accurate, and it is like the Oneway set which costs a lot more, and IS more precise.
I use the hollow cone tip to center the spindle, which I first roughly shape between centers, putting a bevel on the small end to center in this V-cone, and carefully size a short tenon to fit precisely into the turned and hollowed globe.
When I sell these, I use a 3/8" hole in the globe, sometimes a 1/2" hole. When I want to make a real fancy one, I try to work through a 1/4" hole, but that's tougher, and too slow to do at a profit.
Safe spinning,
Brad Vietje (drinking from my CLTL Mmug)
Thetford, VT
Re: Tail center Got it!
Ruth Niles
>Brad,
Thanks for the excellent description of your process. I really like how neat the ornaments look done that way. Here I thought I was finally getting too old to learn something new and now I have to try to learn how to do ornaments this way.
It's a nice big CLTL mug, too!
Ruth
