New WoodChat!
Measuring Threads Per Inch -- Longish
Dave Fuqua
>I recently purchased what I believe is the world's cheapest lathe you can buy -- Cummins Tool off the truck sale for $99.99 (a whopping 2.9 amp motor with sheet metal bed). All I can say is that it does in fact turn. Feel free to LOL or throw out any 'you get what you pay for cliche'. . .
One of the many problems I now have are due to the specs that came with the lathe being way off. The face plate that it came with has a neck with the threads bored off center enough to make using it an adventure. I would like to make, or have made, a new faceplate and am having trouble trying to decide what the diameter and threads per inch should be.
Do you measure diameter from outside edge to outside edge of the threads? Do you measure just outside edge to count up the threads? The specs say 3/4" 8 TPI but I would say that is off -- like everything else. . .
Re: Measuring Threads Per Inch -- Longish
>Dave
Measure the outside of the threads for the size and count the threads from the peak of one to as many as will fit in an inch. Odds are on that lathe it's around 1" x 8 or 1" x12
Fred in NC
>My first lathe was one of those, but from HF. The threads in mine are 3/4"-10, which is a common bolt size. Most of the lathes of that type have the 3/4" spindle but so far I have only heard of either 10 or 16 TPI.
Dave Fuqua
>My bad, it is actually 3/4" by 8 TPI. It only has 7 actual threads. . . Anyone know some good inexpensive sources for getting decent threaded pipe to weld up faceplates? I know some people who weld and the off center plate it came with shakes the machine pretty badly. . .
Arch
>Dave,
No need to put a two dollar faceplate on a one dollar lathe. I assume that the spindle turns true, the plate threads on it and registers or bottoms out against the spindle hub or bearing face. If so don't despair about it being drilled & tapped off center. The work piece will turn true if you screw a block to the off-center plate, true it and fix the workpiece to it. You could scribe a circle concentric to the hub while the plate is revolving, then drill new fixing holes at 3 or 4 points on the scribed circle. You can also drill a hole is a hardwood disc just smaller than the spindle and thread it on the spindle. Take it off, strengthen the wood threads with superglue, drill some fixing holes then turn it true. Use screws or glue to hold the work as a faceplate or glue block.
I hope this dodge helps, or to save you the trouble of trying, someone smarter than me will quickly point out that it won't work! :)
Learn a lot, be careful not to stress your new lathe, think safety, but have fun. Not everyone here started with a trophy lathe or lusts for one. Much nice work has been turned on worse lathes in the past.
Good luck & please share your experience. Best, Arch
You might try truing up the existing face plate. I'd do this with a hand-held angle grinder, probably steadied by the tool rest, turning the lathe by hand if the slowest speed is still to fast. (Turn it with your 3rd hand!) Could be sanded after grinding. Then redrill the screw holes if necessary. I suspect most of the imbalance will be in the outer flange, but you could true up the hub as well.
Don't let the lathe itself stop you from doing great things. My first lathe was a very inexpensive tube lathe with a 1/2hp motor and 3/4" shaft and I made a bunch of stuff with it and learned a lot.
JKJ in East TN
Dave Fuqua
>Arch,
I may give your suggestion a shot this weekend. It isn't so out of balance that it shakes violently when turning something light and already cut down to shape and hollowed, it just makes getting there a bit of a scary, inaccurate proposition when the blank isn't balanced on top of the faceplate not being bored true. . .
I definitely lust after a better lathe and especially turning tools. The few things I have turned on my cheapomatic lathe were made with homemade tools ground from cold chisels and assorted other hand tools. They shape very well, but hollow so-so. Experimenting on the finishing process (including using some good ideas from woodcentral postings) has been fun.
>Go to a hardware store and buy nuts with 3/4" holes and different threads. Buy a 3/4" pipe fitting also. Try them and see if any of them fit. Save your receipt and take them back if you want. If you find the right one, you will know.
I buy nuts from a junk yard and 4" metal disks known as washers or blind plates. They are about 3/8 or 1/2" thick and have a friendly local machinist weld them onto the nuts and true them up. The cost about $5. He may also be able to true up the on you have.
OTOH, Don't spend too much on this lathe. You can't win. If the turning bug bites you, you will be buying a better one soon. Look in the classifieds (Over to the left)or in the local paper or in a Trading Post type paper. Buy one used. There is almost no chance the shaft of the new lathe will be the same as this one and none of you faceplates will work.
Incidentally, Harbor Freight has several sets of turning tools and one of them for $35 actually looks pretty good. Not as good as the high dollar ones from Woodcraft, Etc. but not as bad as that lathe you bought. I bought a set of six because it seems like such a good deal compared to my favorite one that I paid triple that for.
Arch
>Just wondering if the bed is hollow or shaped so it could be stiffened with concrete/rebar or allthread while you are lusting.:) Can you post a pic?
Is the lathe bolted down ?
Fred in NC
>Bolting it to a heavy base will help a great deal !
Re: Is the lathe bolted down ?
Dave Fuqua
>Right now I have it clamped down to a ~200+ lb workbench with a 3" thick butcher block beechwood top I bought off a friend who was moving from VA to NY (an arborist who used find great tree seedlings for my front field and a great source of wood now several states away). I am designing/constructing a homemade bench for this, or hopefully, a small Jet or Delta lathe. . .
Dave Fuqua
>Unfortunately it is shaped to allow for the the tool rest and tailstock to slide back and forth. The space I would like to stiffen up needs to allow the rest and tailstock to slide through. They are tightened down with horizontal handles which isn't such a problem until you work on short peices where the rest and stock are close together, then you wind up having the handles in each other's way and have to play musical adjustment. Not a great design. I particularly enjoy tightening a peice between the stocks and watching the bed buckle as well . . . Yikes!
A shop photo might win messiest shop contest. It is in a converted chicken house on our property that the late previous owner used as a woodworking/electronics repair workshop -- two things that don't necessarily go together -- with relatively frightening wiring. He was a great guy, but an even bigger pack rat than I am.
