We value your privacy.
>I'd like to find a simple, inexpensive source for thin brass cylinders appropriate for tool handle ferrules. Copper, of course, is easy to find, but I prefer brass.
Is it easier/cheaper to find some pieces meant for other purposes, or to just go to a source of actual ferrules?
This brass tubing can be had at lamp stores. It makes a good Ferrule but is tricky to cut square. I made a wooden mandrel with splits that fits in my chuck. I put the brass on and tap a wedge into the wood madrel to hold it and then turn the cut true. Reverse and turn the other side if necessary.
I prefer Brass nipples from the plumbing store. The brass is much thicker makes a much better ferrul. You could use the same method as above to true up the surface but these are thick enough that you can hold them gently in small jaws for your chuck.
My favorite material is brass compression nuts. Both surfaces are already true. You turn the tenon so the thread is a force fit and thread them on the tenon of the handle. I use a crescent wrench to do this. If it goes on too easily I use some CA glue or epoxy. Then turn the hex sides off. This ferrule won't fall off as the years go by but of course does require that you turn the brass or you can leave it as a hex.
>I just use the one's I get from Home Depot in the pluming department. I pick up a number of different size couplings and then use a pipe cutter to cut to size. Works great so far.
>I made six or eight this weekend from a thick walled brass tube (source was MSC Industrial). The problem is that 6' of tube is pretty expensive and you really need various diameters (ie, many tubes). Also need to cut, file, and finish. The Lee Valley catalog has ferrules in various sizes, prefinished, and pretty inexpensive. I'm going there next time.
>Jim That's why I buy Pipe Nipples from the plumbing store. They come in different ID sizes and a lot of different lengts from 3" to a foot or more. If your carefull you can even use the threaded ends by turning the threads off after you glue it in place on the handle.
>Don't you just love the diversity in this group? The one thing you can be sure of when you post a question is that you'll get a lot of different and interesting answers. It's the options that make it fun. Thanks to all for the variety of excellent ideas. ...Gary
I use a 3/8" spindle gouge but I know many people suggest using a scraper. I find the gouge works very well but you have to cut slowly. You can even shear scrape with the bottom lip. Oh I forgot to mention to use HSS chisels. Carbon steel would dull way too quickly.
Occasionally when using used brass of unknown origin you will get a piece that is work hardened. They don't cut well at all. Simply heat it up red hot and quench it. This will anneal it. Before you ask if I got that wrong, it is the same way steel is hardened. Copper and brass are annealed by heating and quenching.
>I just love poking around at the local industrial junk dealer. Found nuts and blind plates to weld together for excellent faceplates, Heavy walled steel tube or pipe called gun barrel that made excellent rails for my table saw and great replacements for the handles like those on the McNaughton System. Sheet stainless and copper, the list goes on. Brass tube for ferrules would be no problem.
Our local metal recycling center used to let us rummage around and buy whatever we found at a by the pound cost. He got scared of liability and will no longer let anyone roam the grounds. Bummer. I used to get some killer deals.
>As a Manufacturing Engineer in the metal working trades, the normal annealing process for brass is to carefully heat to a red or orange glow, then let the piece air cool. As brass is cold worked, it becomes work hardened. Continued working will fracture the material. Annealing will restore the malleable quailty of the material to its original state. The detection of the color change is best determined by not viewing with artificial light. In a controlled environment, the ideal annealing temperature for brass is 930-1020 F. Don't take my word for it check it out on the Web.
>You would have a ball in this place. He actually sorts and resells literally tons of stuff. Need a nut as big as your head? Stainless bolts? Parts for your very own nuclear power plant? A valve you can walk through. I goes on and on. Like some bizarre scavenger hunt. They also shred and sell hundreds of tons of stuff in railroad cars. One day I was tempted to buy a hunk of aluminum about six inches in diameter and four inches deep. Trying to figure how long it would take to turn a bowl out of it on a wood lathe. If I get caught in that part of town with an hour to kill , I walk through.
