New WoodChat!
Running machines via the Dryer plug
Jay in TX
>***Repost from the Main Board***
Ladies and Gents,
This may sound a little nuts, but I'd like to run equipment from the dryer connection. Its the only plug in the house for 240V, but the breaker is 30amp (or better) IIRC. Can I get away with a straight extension cord from the dryer socket to the equipment? built in fuse to the extension cord?
I move about every 2-3 years in my line of work. I don't have any 220-240V equipment yet because of the lack of output (eg. plug outlets for that voltage) in your typical home. I also don't want to wire in every home I live in for the next 10 or so years. Is there a workable/portable solution, or should I just concede to 110V woodbutchering?
I've searched this board and the Main board to no avail. I hate having to rehash what's been here before. I've seen it, but I don't remember what to look for, so I need a little help, advice, slap on hand, or just a good point in the right direction.
Thanks.
Thanks,
~Jay
Re: Running machines via the Dryer plug
Sam Dean
>Make sure the line size is large enough and it shouldn't hurt anything. How far are you going? Longer distances mean more line loss which means larger line sizes will be necessary to carry the same amperage.
Pete L in Holland, MI
>You could build a tempoary distribution box. On a piece of plywood, mount a small breaker box. From that, mount a couple 220v outlets of choice. Install the proper size of breaker. The cord from the box should be sized to handle at least 30 amps. Simply screw the new box to the wall and plug in when necessary. Might not be code, but it'll work.
Kudzu
>Short answer is yes, no problem. Remember the fuse is to protect the wire from overheating and causing a fire. NOTHING ELSE!! A fuse is sized to match the wire it is protecting. 30 amp service is for a 10 ga wire. if you run a cord smaller than this it could overheat before the breaker trips. If you are going a long distance you might want to go to an 8 gage wire but I don't really think that is necessary.
Not to brag but I am a Home Inspector so I know a little something about what I am saying.
