New WoodChat!
air filter advice please
Shawn - in ID
>I know the JDS 750ER is a pretty popular air filter and I've seen several positive postings on it. I was just about to order one when I came across the 3-speed Delta 50-875. The delta is ~$20 less with 1/5 hp motor and CFM of 540, 730 and 1200 (though I can't be sure this is filtered air flow - website looks like 1000CFM filtered might be max); Woodcraft lists it's filtering capacity at 99% down to 1 micron. The JDS is listed at 1/4 hp, 200 or 750 CFM filtered air, 99% to 5 micron and 80% to 1 micron. So, I haven't found any comments on the Delta but it seems a better deal at the current prices. Is their something else I should know about these, or another filter I should consider in this price range (~$250-300)?
Thanks!
Re: air filter advice please
Ed Kelle
>Before I got my JDS, I was looking at the Delta and from what I recall their numbers were higher because they were unfiltered measurements. What I liked even more with JDS was that it had timer features and a remote as well. Its easy to clean that electro prefilter, just vacuum it, or blow air thru from the other side. I'm very happy with mine and know a few others who feel the same way.
JDS
Terry Daniel
>the JDS is better and their service is excellent. The washable static pre-filter saves a bunch of bucks over the long haul. I had a couple of small problems with mine and both times the company has sent me the parts to fix it at no charge even though it was well out of warranty.
TD
