New WoodChat!
Pole Lathe Pen Project
Darrell in Oakville
Darrell in Oakville
>I'm a regular lurker here on the turning board, and this is one of those infrequent times when I actually have something "interesting" to post here.
I've embarked on yet another in a seemingly enless series of lunatic woodworking projects. This time I was trying to turn a pen on a pole lathe. This is an interim report, just a teaser, hopefully to be followed up with the full story next week...
Here's my lathe setup. I have an ironwood (hop hornbeam) pole as the drive spring.
I started with some beech blanks without the brass tubes. Just something to play with as a proof of concept. These went quite well. I set the pen hardware in the finished blanks just to give you an idea:
Then I tried a curly maple blank. Nasty tearout. How nasty? THIS nasty...
My wife Kathy tells me Jim Shaver showed her how to fix this, so I will give the fix a try this week. Next weekend I might be able to complete the project...
Stay tuned!
Darrell
Wood Hoarder, Blade Sharpener, and Occasional Tool User
Re: Pole Lathe Pen Project
john Lucas
>Darrel
Cool, really cool. I find that I need to sharpen my tools to a steeper(sharper) angle for the spring pole lathe. You shouldn't have any trouble with curly maple if the the tools are sharp. On a pole lathe however you may get flex of the pen mandrel. That would cause tearout. How are you driving the pen. I've mostly turned chair legs and such on the pole lathe. never something that small.
Darrell in Oakville
Darrell in Oakville
>John,
I made a drive block with a #2 morse taper socket to take the pen mandrel and the drive rope from the lathe. I'll put together some pix after next weekend's followup attempt. And maybe I'll bring some tools better suited to pen turning than a 1 1/2 inch roughing gouge ;^) Like you, I mostly do chair legs on the pole lathe.
Darrell
john Lucas
>Darrell
I have plans to redo mine so it drives a spindle rather than the piece itself. I wanted to rig it up to take a faceplate or chuck, even though that isn't very factual.
No Problem Darrell
Jim Shaver - Oakville, Ontario
>I see you're having fun at the cottage again!!
Sure, a bit of ca, a new added collar and you have a detail!
take care,
Jim
