New WoodChat!
filling cracks question
ken chase
>When I fill with crazy glue and sawdust it always goes dark and requires touch-up afterwards. Is there a better method?
Re: filling cracks question
mainebowlman
>Ken, I get that look when I use the THIN CA with no sealer on the work.
What's worked for me on the last few bowls is to use medium CA to fill the void. Then I get a bunch of very fine sawdust from the lathe area nearby, sprinkle it on the CA in the void, and rub it in with a latex covered finger. It seems to fill the void pretty invisibly and sand out easily with the next grit.
Jack (at the end of a glorious day here in Maine)
Mike Schwing from Md.
>Ken, Jack is right - the thin CA soaks into the wood and causes the color change. Use a thicker glue - I'd prefer 5 minute epoxy to thick CA personally, but either will work.
Since this is not a structural repair, you could use a sealer of some sort first - shellac for example, and then use CA, but it is still likely to cause trouble - as who hasn't dripped thin CA all over the danged place? Sometimes folks wax the surfaces they don't want glue to stick to, but in this case the internal surfaces are causing problems, too.
I like 5 minute epoxy for this type of work. Clear, hard, and will hold onto a finish, or can be buffed shiny.
Nobody offered the usual response, so here it is....why fill them at all? Crack repairs usually look just like that - crack repairs.
