Re: nat edge advice please
Mike Schwing from Md.
>The answer is simple really - you are not turning the walls to even thickness. The lack of a continuous rim at the same diameter gives you away as it shows the rim thickness through different parts of the bowl. Normally one would only have such an indicator with the entire rim at the max diameter, and that is easy to turn the same thickness all the way around.
There is a bit of an optical illusion involved that can be frustrating with these natural edged rims, but I assure you, the problem can be solved by practicing turning to even thickness on normal edged bowls. I bet if you go back and measure the wall thickness on your finished work you will notice they very much resemble the wall thicknesses depicted on this natural edged one. Even just an 1/8th of an inch looks like a huge difference on a natural edged bowl, but on a regular one, you cannot use your eye to judge wall thickness alone at any point other than the standard rim.
Use calipers if you need to! Eventually you'll no longer be fooled by the illusion and you'll be better at turning to even thickness. It just takes time at the lathe and a desire to do it that way.
