New WoodChat!
Nichols lathe bearings heating up
Wayne Cooper Charlotte NC
>I just received a 'little used' Nichols Lathe from my colleagues at work. I hooked it up Saturday and ran it without any load or wood on it. After 10 minutes the main pillow block bearings were to hot to touch. I had greased them before running the lathe. How hot do the bearings get?? Should I replace the bearings before I begin turnings. They are 1 1/4" Browning bearings. Thanks for any and all help and advise.
Wayne
Re: Nichols lathe bearings heating up
Re: STEALTH GLOAT ALERT!!
>That's a very nice bunch of people you work with!
Sorry, can't help you with the bearing question, but I know that the sealed bearings on my Stubby are designed to run fine up to 250*. You might do better calling a bearings dealer with your question.
Enjoy that fine machine!!
M
Raymond Overman in SC
>Congrats on the new piece of machinery Wayne. I'll have to stop by the ranch and take a look at it. Unfortunately I don't have a lot of info on the bearings either. If they're running too hot to touch though, I would suggest that there is a problem somewhere.
Kudzu
>I would second that. Bearing under no load should not get hot to the touch. Under a load maybe but sounds like there is a problem there. Might want to replace those bearings. I doubt that they cost that much. If they seized up and damaged the shaft that would be very expensive!
Just thought of somthing. Ball bearings or sleeve bearings?
Jerry Glaser
>The problem that you have with the bearings heating up is that you probably have too much grease in them. The churning of the extra grease while the shaft is rotating will cause the bearings to heat up. What should be done is to remove the excess grease from the bearings and leave only about a quarter of what you had. Too much grease is as bad as not enough.
Jerry?
Dave Peebles Lyons, Ohio!
>Hello Jerry,
Is this the famous maker of my favorite tools? Either way, welcome aboard. And thanks for the good info.
Best wishes,
Dave
Re: Jerryor anyone else?
>Jerry
Thanks for the advise. A couple of questions, How hot is too hot?? What is the maximun temperature? It is one thing to be too hot to touch and another is the temperature to hurt the bearing or shaft. How do you remove the grease without disasembling the bearings and shaft??
Thanks Wayne
Wally Dickerman
>I have a Nichols lathe (since 1996). When my lathe was new I experienced having bearings get quite hot. John Nichols told me that if I could hold my hand on a bearing for 10 seconds before it became uncomfortable it wasn't too hot. I agree with Jerry on using too much grease. Just a little, once every few months works for me. The bearings on my lathe run quite cool.
Wally
Re: Jerry?
Jerry Glaser
>It's me. Glad to hear that my tools are doing their job.
