New WoodChat!
One for you bowl fans
tek-Brunswick, Ohio
>This one is a natural edge Ash bowl. Comments welcome on all my postings. Constructive criticism is a good learning tool.
Re: One for you bowl fans
ken chase
>Very nice. I have been making these nat edge bowls and have a question. I have found they require lots of sanding as I can't get the thickness even when both sides are uneven. Is this lack of skill with gouges or normal with this type project.
Thanks
>Good looking bowl. I would have swept the bottom up a little quicker, making it look a little more spherical (?) on the bottom, but that's just me.
Ken, the 'trick' to keeping the edge the same thickness whether it is high or low if to keep the bowl the same thickness as perfectly as you can until you are past the low points and into the 'solid' part.
This one appears to have been beautifully centered on the lathe so that the two tall wings are the same height and the two low points match well. Nice job of making it appear balanced. The hard part about keeping all of it even thickness is tool control. With those wings flying by at nearly invisible speeds, you cannot ride the bevel. You must control the tool off the rest and keep you body parts out of the arc of the wings.
Barry is right on the money.(long)
tek-Brunswick, Ohio
>I have lost sight of the edge a few times on these. This bowls sibling bit the big one when I didn't see the edge. I'm glad I was wearing my face shield at the time. I wasn't going in for the cut yet. I was just setting the gouge down on the rest. Here is what happened. The invisible whirling edge hit the shaft of the unsupported gouge, The gouge slammed down on the rest, gouge bounces back up off of the rest, gouge then bounces off of Trend Airshield, all of this happened faster than I could react of course. I figure I would have had a pretty good goose egg on my upper right forehead if it weren’t for the shield. I had a really lose grip at the time. I wasn't concentrating and was completely relaxed because I didn’t think I was in the vicinity of the whirling wood yet. The bowl split right up the end grain on the high end that hit the gouge. I've lost a litle skin to that invisble edgea few times also. I try to adjust my lighting to have a lot of light on the edge. That does help me to see it.
Ken are you trying to work these to finish while they are still green? I do that here in humid Ohio. You are in a dry area in California if I remember correctly. These bowls will warp as you turn them. The more they warp, the more the inside and outside of the sides are out of parallel. There area couple of workarounds for that. You can rough turn them and then come back and true up the outside and inside after they have dried, just like you do a conventional bowl. Or you can keep misting the piece with water to help keep it from drying so fast. You can try to work the inside of the walls down a step at a time, from the outside in while leaving enough meat toward the center to keep the bowl from warping. If you work the walls down that way too slowly in your low humidity, I suspect you could get some drying checks. Maybe the best way would be to rough the outside then rough hollow the inside and then finish turn by alternately working the outside and inside to finished thickness. Let us know if any of these ideas help.
Tom
Peter Charles Fagg (UK)
>For what it is worth, when I have attempted such bowls I turn the wood at the highest speed possible so that the time lag between the two corners is at the minimum. This also allows, under a strong light, to see the bowl as if it were a complete entity as in a "normal" bowl. Hopefully this gives the turner the impression of turning a complete bowl and the thicknesses are easier to gauge. Seeing the tips is relatively easy if there is a dab of white correction fluid on a piece of sticky tape attached.
Hope this helps, Peter.
