New WoodChat!
Multi-axis turning, fumed Oak stem turning (Long)
Craig Daymon
>Here is a, somewhat awkward, multi-axis turning I did recently. Curly Maple top, Fume White (maybe Red) Oak stem, and Cherry base.
The top started out as a hollowform that I blew throught the side of. (I really love curly stock and couldn't bear to toss it away.) The center is colored with blue PrismaColor marker and the base of the center traced with a woodburning tool. (Can't say I love the look, but I like it more than I did just after I did it.)
The center stem was my first (well, second after the first failed) attempt at multi-axis turning. After I figured out what was going on, it was relatively easy to do. I'm considering a lamp base using this technique. The stem was fumed using Household Ammonia. Two small pyrex dishes were placed on either side of the stem inside an igloo cooler. It was sealed up for about 5 days. Not as fast as using commercial grade ammonia, but MUCH safer and as you can see by the color, very effective. The key is a container that is very air tight. A cooler works great. Remember to keep the item being fumed up on supports so the fumes can get around the object. (Not much of an issue in this case as the ends were tenons to fit into the top and base.) After removing the item, let is off-gas for about a day before finishing. If the process raises the grain (it did for me) it can be sanded as fuming penetrates fairly substantially into the piece.
The base is Cherry. It was Walnut, but that base broke.
Comments? (Go ahead, be brutal. I know it's an odd item.)
-Craig
Re: Multi-axis turning, fumed Oak stem turning (Long)
Another angle
Craig Daymon
>Somewhat blurry, but shows bend in stem better.
>Why be brutal? It's an interesting piece. The fumed oak is a bit unusual and I don't know if I would enjoy turning it as much as the other woods (stringy oak grain and all that). The only "bad" thing I have to say, is that the second photo is a bit too blurry to show off the "knee" in the stem.
Craig Daymon
>Sorry about that. I'm still getting use to the digital camera. It looked GREAT in the preview window. I'll have to remember to use the flash more often.
Forgot to mention that the piece is finished with Watco's Natural.
-Craig
Fuming works with more woods than just oak
Craig Daymon
>I haven't tried it, but Fuming is said to work well to prematurely age Cherry and to darken a number of other woods. There was a great Fine Woodworking article on fuming a few years back that is still available from their site in PDF form for about $3.
The trick to using it with other woods is to paint the other, less tannic acid-rich woods, with a tannic acid solution. According to the article, tannic acid is available in a powdered form that can be mixed with water and applied to other woods. If I remember correctly, the powder is available in the grocery store. If you can't find it, you can always brew up a strong batch of tea and paint that on the wood before fuming. (Let it dry first before fuming.)
Butternut can be darkened to look like Walnut.
Some nice blending effects might be possible by wrapping parts of a project before fuming, keeping those parts from getting as much exposure to the ammonia.
-Craig
