New WoodChat!
REAL MILK PAINT
buffing help please
buffing help please
buffing help please
ken chase
>I wiped my piece with danish oil. How long must I wait to put it through the buffing process?
Thanks
Re: buffing help please
Mike Schwing from Md.
>The correct answer is - until it is cured. How long exactly that takes depends on an awful lot of variables, including - type of oil used, how many coats, how thickly applied, temperature, humidity, etc..
USUALLY, a week after the last coat is enough. Sometimes a day is, but more often than not I find a day just is too "iffy" and the oil heats up and gets all over the place. I've tried to dry it more quickly in the sun, but that resulted in an oozing mess - oil oozed out of the pores after exposure to hot sun.
Experience has taught me that for where I live - mid-Atlantic - one week is enough. In the desert where you are I'd expect a little sooner, but experimentation is in order.
Russ Fairfield
>As Mike said, one week is usually enough. But, the longer the wait, the better will be the finish after the buffing. Full cure takes about 6 weeks for a lacquer, 2 or 3 months for an oil finish, and 2 years for shellac.
Do an experiment. Take two similar pieces, wait a week with one and a month for the other before buffing. You should be able to see a difference. If you can't, then you have answered your own question.
At the least, you should wait until the surface film comes off as a dry white powder when abraded with 0000-steel wool, and there should be NO SMELL of the thinners. A fully cured finish has no odor.
