New WoodChat!
Radio Help (a little OT)
Bert Smith
>I finished building my new shop this past February. All of a sudden this week my radio has been full of static on my previously clear FM stations. When I switch off my lighting, the signal clears up.
I thought there was a thread on flourescent bulbs interfering with radios, but I can't find it.
I've already missed "Car Talk" this morning, so any help will be greatly appreciated!
Thanks,
Bert
Re: Radio Help (a little OT)
Don Emmerling
>Hi Bert
I would imagine that the interference is coming from older type balasts in the light fixture. I am just guessing here that the fixtures are of the older type as this same thing happened to me. The new ones do not put out so much electromagnetics.
Regards,
Don
Walter Ahlgrim
>The first thing I would check is if all the light fixtures are grounded. At the fixture measure from the black wire to the bare metal of the body of the fixture. Ideally the voltage would be the same as from black wire to white wire but if it’s up to 2 volts lower that’s ok. Check each fixture.
Are the new shops walls or roof made of steel?
Bert Smith
>All of the lights are new and I grounded them during installation. What bothers me is the fact that the shop is about 5 months old and the static didn't start until last week. I've tried other outlets, and I have many on different circuits, with no success.
I'll go to Radio Shack tomorrow and see if I can purchase some type of filter to plug the radio into. If not, I may just use a battery operated radio.
Thanks for the info,
Bert
Bill Crommett
>Bert: Before I would spend any money, I would unplug each light ---one at a time-- until you find the culprit. Then you can follow up with a pourpose.
JamieDonaldson
>I know that Radio Shack has a selection of RF filters that might help, but first try to find the source. And my week is off to a bad start when I miss Click & Clack!
