We value your privacy.
>Ever since I've had my lathe I've been plagued by the tail stock slipping when I tighten the centers. I can never get it tight enough, and midway through turning the drive center stops gripping the work piece. The other day I took the tail stock off the lathe to see if I could get a clue what causes this and I noticed that a previous owner had painted the washer that is at the bottom of the bolt -- could this be the problem? does painted metal just not grip as well as bare metal? If so, how would I go about replacing such a part? A friend of mine suggested using an anti-slip spray on the washer and the bottom of the lathe bed but I'm not sure I want to go that route.
>Why don't you just clean the paint off and give it a try? I would use medium sand paper. There may be an adjustment. I had to tighten the bolt hold the square washer on my banjo. If your washer is round or there is enough room you might try a square on or a slightly larger one. A machinist could make you one if a standard one won't work.
>Just take a belt sander or what ever you have and sand the paint off. If that doesn't work trying adding another washer. Could be that your not able to tighten enough.
It could be the washer but odds are it's the bottom of the tailstock not being perfectly flat with the bed. Probably both. This is a common problem among lathes, particularly less expensive models. I would definitely try tightening and possibly sanding the nut first. Trueing up the bottom of the tailstock is much harder and takes a lot of patience. Basically you put machinists dye on the bottom of the tailstock and then slide it back and forth on the bed. You'll rubb some off. These are the high spots. Sand them lightly with maybe 400 grit. Then repeat. This takes a while but worked successfully on my old J-line lathe.
There is another method that I'm not totally familar with and has something to do with putting abrasive on the bed and rubbing the tailstock on it. I'm not sure if that's the exact process and was worried about abrading the bed so I stuck to the other method. Maybe someone else knows how to do this.
Machinists use a technique that I think is called Scraping to true up a lathe bed but I haven't seen that done and don't know the process.
>I had pretty much the same problem you describe on my Grizzly 12” tailstock. In my case the nut kept loosening itself and if I tightened it to the point that the tailstock would lock securely I then had problems sliding the tailstock on the ways due to inconsistent machining on the underside of the ways. To solve this issue I removed the bolt from the tailstock and went to an auto supply store and found a spring that fit over the bolt. I then reassembled the tailstock with the spring between the bolt and the locking plate. I then added some locktight to the nut and adjusted it so it was tight enough to create a secure lock with a quarter turn of the locking handle. The spring holds the plate down so the tailstock slides well along the ways and I have had no issue with a creeping tailstock since.
Sounds like the problem is that the tailstock itself is creeping -- not the ram that is advanced when you rotate the wheel, no ?
I agree with John Lucas -- the machining on many lathes (like mine) isn't that great. If the bottom of the tailstock mates exactly with the top of the bed, you should be able to get a good grip that won't slip.
You can blacken the bottom of the casting with a permenant marker, and run the tailstock back and forth along the bed, and see where the ink wears off first. These are high spots that need to be brought down a bit. I might start with 220 or 320, though, instead of 400.
Another option, which works well, but doesn't look great, is mentioned in one of David Ellsworth's tapes. Turn a chunk of green Red Oak into shavings -- practice cuts with whatever tool you want some practice with... Now pile those wet shavings on the cast iron bed, and leave them there overnight. In the morning, your lathe bed will be covered with a very fine rust -- yup, rust. After cleaning the bed with some steel wool it should grip the tailstock much better. I'm not suggesting you get the thing all pitted and crusty, as if it had been in salt water, just a fine, brown coating, which you buff back to a slight bronze tinge. There are some who cringe at the idea of getting any rust on their precious lathe bed, and worry about getting it off -- a fools errand; it will work better with an oxidized patina anyway.
>The word I remember is "frosting"; and it is a pattern of half-moon gouges that are cut into the surface of the steel or cast iron that has already been planed and surface ground to a smooth flat surface. The frosting is cut with a scraper, and its purpose is to provide recesses that will capture an oil film to lubricate 2 flat sliding surfaces.
The rust on the ways will give the tailstock and tool rest locks a better grip; but it will also make them harder to move when you want them to.
>Jeremy One last suggestion. I have a friend who has a lathe that has terrible tailstock creep. he puts a C clamp on the bed behind the tailstock. It works great. Not the solution I would use but he's perfectly happy with it and it does work.
