New WoodChat!
thin walled green bowl
DWFII
>I have a natural edge maple bowl I am beginning to turn. It's green and prone to crack (sitting in a plastic bacg with shavings right this minute). If I wanted to turn it down thin enough to let it finish drying (or maybe help it with a microwave) without fear of cracking, how thin should it be?
What about the base? Can it be thicker?
Any tips on the procedure here would be much appreciated...
DW
In the High Desert of Central Oregon
Re: thin walled green bowl
Ruth Niles
>DW,
The important thing is the bowl be of uniform thickness. Ideally the bottom should be the same. Take it down as thin as you dare, no more than 1/4", 1/8" is about perfect, 1/16" is impressive! : )
Don't leave it in the plastic bag too long (like take it out now) because green maple will get mold spots.
The bowl will warp, but warping on natural edge looks neat, sort of an optical illusion, but it shouldn't crack with even wall thickness.
I know nothing about microwave, don't own one.
Ruth
www.torne-lignum.com
DWFII
>Ruth,
Thanks for taking the time to help someone doing this for the firt time. After almost 70 hits, I thought this was gonna be a question without an answer.
I think it's gonna get a little scary trying to do a base that will support the bowl **after drying** and yet get the walls down thin enough to dry on their own.
I'll take the bowl out right away.
thanks again...
Carole in VA
>Don't have time to look right now, but if you can, grab a copy of "Turning Green Wood" by...darn, the author's name escapes me. Not much help am I? Anyway, he goes into great detail about turning it thin and drying in the micro. Since I am useless here, I'll go back to what I was doing! LOL
Mike Swain
>The guy's name is Michael O'Donnell and it is a very helpful book if you want to turn wet timber.
I turn most of my work wet and to roughly 2mm wall thickness and then dry them in a microwave. It does help if the thickness is even all the way. If you move to more of a closed form shape, I have found there is little or no movement at all.
This piece "If Wishes Were Kisses" is in English sycamore and measures 10" tall by about 7" in diameter.
I'm sure a quick search on Woodcentral will bring up the details on using drying a microwave for drying.
Regards....Mike Swain RPT
Ron in Drums PA
>Real nice Mike, I would have thought it was made of glass.
Dick Hines
Dick Hines
>Mike, you are getting good with that air brush. A little more practice and you will be doing custom bikes.
Mike Swain
>Hi Dick,
Custom bikes in the UK are pretty rare, just about the only ones we see over here are on the TV programmes imported from the US.
I've been thinking about doing a vase with skulls or maybe even flames!!!!!!!!
