New WoodChat!
Bleached Ash
Bleached Ash
Bleached Ash
Two Ton Tommy
>I have bleached an ash HF that I recently completed and have that white stone look that I was striving to get. My problem is what finish to use that will not leave a yellow tint. Which would in essence make it look like the ash before the bleaching. Prior to bleaching, I heavily sand blasted the peice to provide great contrast in the grain which all but eliminates using just Beal buffing (too rough in the soft wood grain). I know somebody out there, through trail and error, has come up with a solution that I could benefit from. Thanks in advance for any help.
Re: Bleached Ash
Re: Bleached Ash
>two ton tommy
I use Krylon Fixatif on my wire brushed vessels. They are similar to sandblasted. It also changes the color about as little as any finish.
Re: Bleached Ash
Re: Bleached Ash
Russ Fairfield
>The only thing you can put on the wood that will not change the appearance of the piece or "yellow" with age is nothing. If you like what you have, leave it like it is. There is no law that says that wood has to be coated with something.
Re: Bleached Ash
Re: Bleached Ash
>2-ton,
The acrylic resin finishes (Minwax Polycrylic, etc.) will go on water clear, but their water base will raise the grain on your piece further. This will likely put you into a light sanding situation. Extra care must be taken because the whitened fiber layer of wood is actually quite thin, so it's easy to sand through to the darker wood underneath. Keep in mind, too, that with water-base and waterborne (Fuhr, Oxford) finishes you must stay far away from steel wool as the small particles it leaves in the grain will rust and discolor your piece. I'd suggest you do a few test pieces with different finishes since the various formulations produce coatings with different refractive qualities. For instance, I think the Minwax products' films have a distinctly blue cast in sunlight, but Varathane Elite has a warmer tone when cured.
I have heard of using Krylon Fixatif or Zinsser's SealCoat (bleached/dewaxed shellac) as a sealer in this situation, but since I haven't actually tried them in your application, I don't know that they won't give some slight tint to your wood.
Of course if you really want white wood, you can give the piece a thin coat of white pigmented sealer or white lacquer and then clear-coat over that. Just be carefull about compatibility issues.
Post a picture or 2.
Good Luck
Re: Bleached Ash
Re: Bleached Ash
>Mark hit on the best technique. Make a scrap piece and divide it up and try 3 or 4 finishes. That's the only way to really know because each wood/finish combination looks different.
Re: Bleached Ash
Re: PS
>Russ is quite correct.
Every finish or coating will, given time, show its age and the effects of light. Note too that even breached wood, finished or left raw, will naturally darken with age and can change color in a rather short period of time depending on conditions and the kind of wood.
M
