New WoodChat!
Veritas - Innovation in Tools
truing up grinder wheels
Dennis Taylor
>I have been having some probs sharpening my gouges..I have a 8in Woodcraft grinder with a white & a pink wheel..I noticed the wheel(white) I use for my gouges isn't running true ..it has a wobble...I can clean the face with a diamond but it wobbles when I look at it..is that a problem?..how to fix?...Dennis
Re: truing up grinder wheels
It's the mounting flanges
Terry Daniel
>Dennis, you might rotate the mounting flanges (washers) and see if you can find a better combination; you're problem is the wheel isn't 90 degrees to the shaft. If you cannot get it right and the grinder is under warranty I would take it back and try another. If there is no warranty, then order the One-way balancing kit which includes flanges that will hold the wheel 90 degrees to the shaft. Do not dress the sides of the wheel as this will throw the whole thing badly out of balance.
TD
James L. Seigal
>Dennis, the Oneway balancing system requires a 1" hole to work. If the grinder shaft is ok,You can take care of the wobble by shimming between the inside flange and wheel with masking tape. Jim S.
john Lucas
>I found paper and metal shims also work.
Don Orr
>I just saw in the Lee Valley catalog that the Oneway balancing system is now available for 3/4" and 5/8" shafts too. I need to get one for myself one of these days! Good Luck!
Turn your own hubs and improve the flanges
Jay in TX
>I have a Woodcraft grinder with the same problem. I worked great out of the box, but when I upgraded the wheels I noticed the wobble you're talking about. If yours is still under warranty (1 year/no questions with receipt) then by all means take it back, but don't expect a duplicate machine to perform much better. We all make sacrifices to the budget gods. I'd like a Baldor grinder, but I don't see one in the near future.
So if you're going to keep your current machine you may want to try this, it worked for me:
1. Take off the wheels/flanges.
2. Lightly drag the flange faces (the faces touching the grinding wheels) across some 600 grit or other fine grit sandpaper laid on a hard flat surface. Just enough to show an even sanding pattern about a 1/16th wide. This will improve contact with the wheel with less deflection during tightening/adjustment (IMO, but I'm not an engineer).
3. Grab a piece of hard/dense scrap (sugar maple or similar, I wouldn't use a wood with high tannin content). I used a couple of tiny pieces of cocobolo.
4. Drill a 5/8" hole in each and then mount them on the lathe and turn the outer diameter to snugly fit the hole in your grinding wheel (approx. 1"). Its essential to to make the outer diameter parallel to the inner diameter.
5. Remove the plastic hubs in you grinder wheels and replace them with your new wooden ones. Doing this should help with aligning the wheels perpendicular to the drive shaft when remounted.
6. Remount your flanges and wheels. Do this one at a time checking for wobble by rotating the respective wheel by hand. If you still see wobble, then rotate one flange about 90 degrees, retighten and check. No wobble? Great! But if there's still a little wobble keep trying. Once you've found the place of least wobble on that side, mark it and then do the same for the flange on the other side of the wheel.
7. Follow the process in 6 above for the other wheel.
Now you should either be wobble free (EXCELLENT), or very little wobble (about .03 on my left and about .02 on the right). So let us know how everything works out for you.
~Jay Kilpatrick
