New WoodChat!
imput for nat.edge bowl
ken chase
>This oak piece is my first. It is not finished. Has a coat of shellac. The variation is grain pattern is and color is my concern. Would this piece be best if it were tinted or dyed? Did I make the right choice leaving only part of the bark? Also, as it is quite thin I finished it green and skipped the drying process. Given the banana shape a little distortion shouldn't matter....I guess?
Thanks
Re: imput for nat.edge bowl
ken chase
>Another photo
Re:smaller photo
ken chase
Re:smaller photo
ken chase
photo size question
ken chase
>I made this smaller in photoshop but it is still large on the post. How can I size it down?
>I think that it is a superb bowl. If you want to dye it, fine. Just don't hide that pretty grain swirl.
Carole in VA
>Ken, I don't understand your concern with the variation in grain pattern. That is the beauty of wood. In fact I probably spend more time looking for wacky wood than I should. The wilder the grain, the better! Don't hide it...flaunt it! That's a very nice looking piece. Distortion, IMHO, is not always a bad thing. It can add drama to a piece.
Bob R WestMac Turning
>What is the bowl size?
Great Grain and shape...
Bob R
Re: photo size question
What did you do in Photoshop? You need to use the Image/Image Size command, make sure "Resample Image" is enabled at the bottom of the dialog, enable "Constrain Proportions", and change the pixel width at the top of the dialog. Something like 500 is a good size.
Then save as a JPG, adjusting the quality value until you get the file size right for upload. If your version of Photoshop has a "Save for Web" command, this last part is easy. Choose "Save for Web", click the little triangular Optimize menu button at the right, choose "Optimize to File Size" from the menu, enter 80K or whatever file size you desire, click OK, then click Save.
JKJ in East TN
Carole in VA
>When you optimize for file size under save for web, you still should set the image size to 400-600 pixels first. Otherwise the image is still so big it won't fit in the window and viewers have to scroll. After that is done, THEN optimize to file size. This also has the advantage of starting with a smaller file for optimizing so less detail must be compromised to get the desired file size.
tek-Brunswick, Ohio
>"Given the banana shape a little distortion shouldn't matter....I guess?" The bottom may warp when it dries. If its rocks too much for your tastes after it dries you may have to flaten the bottom, either on the lathe or with a disk sander. I had to flatten the bottoms on some of the bowls I turned green.
