New WoodChat!
Have a question? Ask Woody!
shaving booth
shaving booth
shaving booth
>Ron reminded me I need to make a sort of shaving booth or shaving containment area. I roughed out this really out of round oak blank this weekend and had shavings in an 8 to 10 foot circle all over the shop. I really don't like that and want to contain them in a smaller area.
I thought about roll up clear plastic but in the summer I'm going to need the breeze to stay cool. I thought about roll up mosquito netting which would allow the breeze to pass and maybe stop some of the bugs but the shavings will stick to it.
I'm wondering if something like a mini blind might work. I don't want to block out all the outside light but that may not be an option. I figure if you tilt the slats so they point inside the shavings would fall off but the breeze and some light would still pass through.
What do you all do. If I had room I'd just build a big funnel around the lathe. Maybe I could build a cove wall, then I would have a photo studio in my shop and no corners to sweep up. I might even be able to write that off my taxes.
Re: shaving booth
Re: Shower curtains
Re: shaving booth
Re: shaving booth
Duane C.Leach
>John I use a curtin of plastic but it doesn't extend to the floor. The bottem of the curtian is about 30" off the floor. High enough to knock down shavings but high enough to allow breeze from fan to blow through.
Happy turning.
Duane
Re: shaving booth
Re: shaving booth
David Propst
>Hi John,
My shop is in my basement, so I have floor joists convienient for hanging stuff. I used conduit and made a "U" shaped shower curtain rod around the sides and back of my lathe and ran another behind me to keep the shavings off my wood rack (e.g. indoor wood pile).
I used cheap clear shower curtains. I can enclose the area if I need and keep it open the rest of the time. Shavings are probably 95% contained, there are always a few which fly over the rod.
One day when I have my big open shop with skylights and french doors I'll have to work up another solution.
Good luck,
David
Re: shaving booth
Re: shaving booth
tek-Brunswick, Ohio
>Some of the members in our club use roll up Bamboo Screens. They are made for porches, I think, and are inexpensive.
Re: shaving booth
Re: shaving booth
>I thought about the bamboo curtains but was afraid they would block too much light. They are cheap and come in large widths.
Re: shaving booth
Re: shaving booth
>That sounds like a possible idea. Most shaving do go up instead of down.
Re: shaving booth
Re: shaving booth
>so get the white plastic bamboo substitutes in a roll-up shade.
Re: shaving booth
Re: shaving booth
>Mark
If I was really good I'd just get a 50 gallon barrel and aim my shavings to they would all hit the opening.
Someone just sent me a tip, he backs a small trailer in his shop up the the lathe and claims that most of the shavings fall in the trailer.
I must be doing something wrong because I have shavings in almost 180 degrees the bowl. The majority go over my left shoulder or about 45 degrees to the right depending on what part of the bowl I cutting or right or left handed.
Re: shaving booth
Re: Doin' It Wrong
>You and me BOTH |:-}}}}
Re: shaving booth
I have tried this ..
Fred in NC
>Fan behind and to one side of me. Blows the chips away from me, and a good part of them go into the suction funnel.
Re: shaving booth
Re: shaving booth
Ed in No.VA
>Why do you need a booth just shave in the bathroom. :>}
Re: shaving booth
Re: shaving booth
>Ed
Half the time I'm shaving in the car on the way to work because I was trying to get some last minute thing done in the shop.
