dyed vessels for TD
Joe Fleming - SD
dyed vessels for TD
Joe Fleming - SD
Re: dyed vessels for TD
Joe Fleming - SD
Joe Fleming - SD
Joe Fleming - SD
>All very pretty. The blue one reminds me of the color of one of the fancy bowling balls.
Terry Daniel
>Thanks Joe. These are a totally different look from what I got but very nice. I'll try to post a pic of mine shortly.
TD
Jim D.
>Joe,
Very nice work. Can you give a little info on them, type of wood, finish, ect...?
Jim D.
Carole in VA
>Very nice, Joe. You might think about reducing the physical size of your images to about 400-600 pixels wide, but keeping the quality a little higher. That way you can bring the file down to an acceptable size but avoid the jpg "artifacts" (the blocky effect)
Joe Fleming
>Thanks Carole, I'll try that next time.
On finishing, the very short answer is that I used a derivative of Don Derry's finishing process. For those that want all the details, I recommend you go to WoodWorker West magazine (www.woodwest.com). The July-August 2003 issue has an article by Don.
Briefly: turn, sand, bleach to near white (blue piece only), seal with sanding sealer, color with airbrush (thanks Russ), lacquer - many coats to build, sand to dead flat (no dimples, divots, or other imperfections in the lacquer, polish to high gloss with automotive rubbing compounds.
Joe
