New WoodChat!
REAL MILK PAINT
Russian Olive
Russian Olive
Russian Olive
tek-Brunswick, Ohio
>Has anyone turned Russian Olive? Some of the wood left over from the Cabin Project I was working on was Russian Olive. I got some pieces of that and some Ash from the left over logs. I know Ash turns well, but I'm not sure about the Russian Olive.
Re: Russian Olive
Re: Russian Olive
LT
>I'm a newbie, but for what it's worth I've turned several bowls out of russian olive. The bowls I have turned were all soaked in alcohol and were very stable with minimal movement.
Be sure and seal the ends of the log as it will develop checks in the end grain pretty quickly.
Turns very easily when wet. It can be a little hard and chippy when dry. It sands and finishes well, and the ones I turned were light to golden brown with a pronounced grain pattern.
I would go for it. Hope this helps.
Re: Russian Olive
Re: Russian Olive
Ed in No.VA
>It can also have a nice brown patterned heartwood.
Re: Russian Olive
Re: Russian Olive
e
>i bet that the common name 'russian olive' is used for more than one species. but here's a picture of the russiaan olive i turned.
it smelled heavenly and turned very well. not much movement and was easily carved.
Re: Russian Olive
Thanks
tek-Brunswick, Ohio
>That is a nice bowl -e! That looks like the wood I got. Lots of nice brown heartwood and about an inch of creamy colored sapwood. I hope my turnings turn out at least half as good as yours.
Tom
Re: Russian Olive
Re: Russian Olive
Don Henthorn
>e, care to share how you got those little legs on that beautiful bowl?
Re: Russian Olive
Re: Russian Olive
e
>tek: i hope you enjoy the wood -- it's really fun to work on, and i loved the smell
the legs are carved from the chuck-tenon. after piece is entirely finished, the piece is reverse-chucked (or jam-chucked). the tenon is then shaped into the leg-shape. then, off the lathe, the tenon is cut-out leaving enough wood to carve the legs.
Re: Russian Olive
Re: Russian Olive
Don Henthorn
>Thanks,e, just curious.
