New WoodChat!
A55 Smoothing Plane
plywood for doughnut chuck?
ken chase
>3/4 " Baltic birch ply is not available to me. Would it be all right to use regular birch plywood to build a doughnut chuck? I haven't turned plywood and note the directions say to true the ply. Does it turn like ordinary wood?
Thanks
Re: plywood for doughnut chuck?
>Most any good grade of plywood will do. Baltic birch is more preferable as the plys are more superior than the typical "chopped" wood. I have used MDF for some of my forms (it was free).
Colin Spencer
>Any ply will do it is just that Baltic birch is better (and more expensive). Mine is just made from the best ply that I could obtain (definitely not Baltic or Birch). Bear in mind that plywood is glued together and you will have some cross grain and there is a lot of glue use a freshly sharpened tool to get the best finish.
Ron in Drums PA
>The problem with plywood is there are voids. When you are cutting a hole to make a donut you will not know if you going to have a void in a critical spot until you are finished making the cut.
Baltic Birch is "supposed" to be void free.
BTW ply doesn't turn like regular wood, but you will not have any problems.
Bob R WestMac Turning
>I was wondering about a doughnut yesterday. I have seen the term used a number of times. What is the way to build one??
Thanks
Bob R
Re: plywood for doughnut chuck? *LINK*
Ron in Drums PA
>First you need a good cup of coffee then you click on the following link.
Bill Grumbine's website
>Ron
Coffe or maybe someting else. This is what I was looking for.
This will make the bottoms a lot easier to make lot real pro. (maybe not, just not real amatuer).
Thanks a lot
Bob R
A better Doughnut Chuck plan/article *LINK*
Craig Daymon
>Sorry Bill, personal opinion only. I'm certain both work as well.
Art Liestman wrote an article on his Doughnut Chuck for Canadian Woodworking magazine. It is, my opinion, a clearer article on the subject. Either way, it doesn't take much to grab both and compare for yourself.
I put the link to the PDF of the article below. For those that don't know, right click on the artcle and choose "Save Link Target As..." (or whatever the equivalent virus ridden option is in Internet Explorer). Just clicking on it will also likely launch Acrobat Reader and you can view it and optionally save it that way.
-Craig
Art Liestman Doughnut Chuck (PDF) article
Bill Turpin in WNC mountains
>There is a manufacturing plant that I drive by daily that throws away 10 to 20 large electrical spools weekly. They are 13 ply, full 3/4", void free plywood that has exterior glue. Pieces of about 12" x 24" can be recovered for jigs and small projects after cutting out the dados used in spool assembly. This is excellent wood and it's FREE. Most electrical supply houses and E contractors throw these away in all parts of the country.
Bill in WNC mountains
Warning from Newly Acquired Experience
TomW in SouthJersey
>Here's a word of caution. I built one tonight after seeing the posts and reading Bill's website. I used 3/4" oak plywood and attached it to my Nova 6 inch faceplate.
I have just finished a 12 X 5 1/2 inch cherry bowl that needed the bottom turned off.
Two big things went wrong from there.
First, I had used too small of a screw to secure the donut/compression chuck to the faceplate.
Second, I had just finished waxing the bowl at 2,160 RPM and forgot in my excitement to check out the new chuck.
The screws gave loose the chuck with cherry bowl went straight up still spinning at close to 2100 RPMs. My son's friend who was watching managed to duck. Instictively but stupidly I tried to grab the spinning mass out of the air.
Fortunatley all I have are swollen, bruised and cut fingers and arms. It could have been much worse.
Use the largest bolts that will fit to attach the compression chuck to the faceplate and test it at s-l-o-w speeds.
My bowl only received minor scratches but I think I'm trying a tape chuck....
Tom Wright
And Don't try to catch a falling knife!
>Don't spit into the wind.....
John, Maybe it would be a Good Idea to post the Speed Limit on some of these things. Start slow and sneak up on it. I'm not sure but if you try 2160 RPM on a twelve inch tape chuck you might end up looking like the mummy.
What an interesting CSI Episode "Hmmm? This guy is dead from blunt force trauma and skid marks but somehow managed to wrap himself in blue painters tape before he died. Didn't keep him alive, but it did minimize the bleeding. Must be a turner."
That dough nut chuck is huge or at least large, the RPMs should be in the hundreds, not thousands. In Raffan's book Turning Bowls he has a chart and the highest speed he recommends is 1800 for a 4" bowl and 1400 for a shallow 10" bowl. And that's just for the bowl. Speed kills.
Also, be very aware that those bolts that hold the chuck together would be very dangerous. If you manage to get a hand or finger between one and the bowl, you won't want to do it again. I casually reached out and tough my Nova scroll shuck while it was spinning. A finger tip went into one of the holes for the chuck key. I was lucky and got a minor "bite", but if it had gone just a little deeper it would have been a disaster. It was a warning.
Re: And Don't try to catch a falling knife!
TomW in SouthJersey
>Reaching to grab it was a instant reaction trying to save the bowl I spent so much time on. I don't know why I did that. I know 2160 RPMs is way too much for anything of that mass. It was forgotten while bragging about the new gizmo I had just made.
I'm going to use bolts to hold the donut chuck to the faceplate. And you betcha I will be speed conscious every time I start the lathe.
A trip to the doctor is in order today. right thumb is quite swollen and hurts like crazy to use it to turn a door knob. (I checked. I can grasp the throttle on my motorcycle :-} )
...or stop a falling anvil with your foot
>I knew of a guy at a pipe fabrication facility where I used to work who tried to stop a rolling long 18" dia schedule 160 pipe with his foot, a common practice for smaller and lighter pipes. It folded the steel toe over and crushed his foot.
I've gotten into the habit of turning the speed down just before switching on the lathe while turning. I don't do this while sanding/finishing since then I tend to turn it on and off a lot more. I started this after accidentally having the speed up way too high one day.
As a safety feature, I think the ultimate lathe would have an adjustable maximum speed control stop which could be set low when working on larger things, high for tiny spindles. This would be especially helpful when teaching an inexperienced person.
Another nice safety option would be a speed control that reset itself to zero each time the lathe is turned off. I know not everyone would want this, but it would make a nice option.
JKJ in East TN
Re: And Don't
>"Pull the mask in the Ol' Lone Ranger,
An' don't mess around with Jim."
Sorry, couldn't resist.
Heal soon, Tom.
(you ever coming up for some walnut? It won't fit on a motorcycle though.)
Mark
Re: And Don't
TomW in SouthJersey
>Mark - I don't have a need for walnut at the moment I have 12 DNA dried and roughed walnut bowls irritating my wife in the dining room. But I'll take a raincheck on the offer.
But I'd like to stop up to see the shop. Besides you live near some nice roads for motorycles.
Update - Doc says its probably not broken. So now I need to clean up the scratches on the bowl, reapply the several coats of Danish oil and give that new (and improved) donut chuck a nice slow speed try.
Tom
Re: I looked
>at the donut deal and quickly decided that either a jam chuck or the vacuum thing were "MY" alternatives.
Roads are fine when the deer stay in the woods, and there's a Harley dealer in town.
C'mon up!
Re: Oops, Forgot
>You're a Honda-guy right?
Re: Oops, Forgot
TomW in SouthJersey
>Yeah. I actually ride it.
Don Henthorn
>One thing that I do with the doughnut chuck that I haven't seen on some of the plans is to run a nut down each bolt to hold the bolt ridgidly in the part with the hole in it. Then I assemble the bowl and chuck and use wing nuts or regular nuts to hold the assembly together. If the bolts are not held rigidly a catch is more likely and much more catastrophic.
