doughnut or Adjusta-jaws ?
ken chase
>Without considering cost savings am I better served with a homemade doughnut or a Vicmarc adjustajaw chuck? I don't mind the expense and have not used either chuck. Imput will be greatly appreciated.
ken chase
Re: doughnut or Adjusta-jaws ?
>Ken
I use 6 methods. Vacuum chuck, Vicmarc jaws, Homemade adjustable jaws, and Big blank piece of wood that I can screw or jam fit anything to,I've also made several doughnuts to fit this, the 8" long log screwed to a faceplate that I use to do natural edge bowls. These 5 methods allow me to hold almost anything.
If you do nothing but flat topped bowls it's hard to beat the vicmarc jaws. They work great but limit you in size. If you have a 20" lathe you can only do a bowl about 17" or so because of the jaw size and the need to compress the jaws from the max setting to hold the bowl. This is also a consideration for the doughnut.
With a doughnut faceplate you have the advantage of being able to hold odd shaped bowls because you can turn a piece to fit on the chuck that will sit inside the bowl and support the bottom. The dougnut will then hold the outside. This takes some tinkering to get it aligned sometimes. If the wood you use for a faceplate is thick enough you can also use this as a jam chuck to align bowls, then use the tailstock to hold them in place while you turn the bottom.
The vacuum chuck is great but if the bowl has holes you have to seal them with tape or something to make it work. This is great for natural edge bowls and is realy fast but is the most expensive of the reverse chucking methods.
Because I start most of my bowls between centers with the bottom toward the tailstock there is a center mark that I try to leave. Then I use this center mark and my 8" long by 3" log with rubber on the tip to align and reverse turn the bottom. This is probably my most used item for small bowls. The vacuum chuck is definitely the most used for natural edge and large bowls.
Bob R WestMac Turning
>John:
I am new to bowl turning (i have self taught myself segment bowl turning ,very basic so far).
You mention terms like doughnut face plate and log screw to face plate for for turning. Can you please help a newbe. Any and all help is much needed.
I don't want to be buying more tools until i know what is really needed for rather basic bowl turning as a hobby.
You can E-mail me so as not to bother the regulars on the site.
THANKS
BobR WestMac Turning
Please bother the Regulars
>I'm here all the time and I have been turning for years and I still don't know what a donut is. Would one of you please explain?
Donut Chuck - Bill Grumbine's page *LINK*
Stuart Johnson
http://www.enter.net/~ultradad/bowljig.html
vicmarc jumbo jaws
john Lucas
>Here's a photo of the vicmarc jumbo jaws with a small bowl. You can move the red rubber jaws out to do larger jaws. You can even do square bowls, platters and other things. It's nice but you do have to screw the jaws on each time or dedicate a chuck to those jaws. Yu can modify all sorts of jaws to fit the screw holes or slots.
jumbo jaws, square bowl ?
john Lucas
>This is how you can hold a square bowl. This one is out of square but sometimes you can still get buy.
Re: Donut Chuck - Bill Grumbine's page
>Thanks. I actually knew what that was, just did not know it by that name. Really. I thought about making one, but I have so many other ways of reversing a bowl I haven't been pushed into it.
homemade chuck
john Lucas
>Here is a home made chuck. You can make the jaws any size. I put cork on the bottom to hold the bowls.
faceplate chuck
john Lucas
>This is a large faceplate that I cut grooves or tenons in to center and drive bowls. I use the tailstock to support it.
Extenstion chuck
john Lucas
>Here is my most frequently used reverse chuck besides the vacuum chuck. This is valuable if you like to turn very thin bowls. You can crack them with the Jumbo jaws and you can blow them up with a vac chuck.
Re: Extenstion chuck in use
john Lucas
>Here it is in use. I use a high friction rubber on the front of the chuck but many people use sandpaper.
vacuum chuck
john Lucas
>Here is a quick shot of my homemade vacuum chuck. It's PVC with neoprene O ring on the lip. You do need a vacuum pump to use this. There are some good sites on the web about vacuum chucking I won't go into that.
Re: vacuum chuck in use
john Lucas
>The advantage of a vacuum chuck is that you have total access to the bottom of the bowl. It's also very quick. www.bestwoodtools.com sells a #2 morse taper that's threaded the same as your lathe. You take the chuck with bowl in it and screw this gadget into it. Then you put all that in the tailstock. Now put the vacuum chuck on and push the tailstock with bowl on it up to the chuck. Turn on the vacuum and then release the bowl from the chuck. It is now perfectly centered and ready to be turned.
tape chuck
john Lucas
>For years I used either tape or inner tubes to tie bowls to a scrap faceplate of wood. It's amazing how well this works. Especially with the clear stretch wrap.
Often you will have to "reinvent" a chuck using combinations of some of the ones I showed you above. I don't have many of the chucks I have "reinvented" because they were one time only things designed to finish that particular piece.
I didn't discuss the longworth chuck or doughnut chuck because there is a lot of information on the longworth chuck and bill's photo of the doughnut chuck is quite good.
Dear Mr. Lucas .
Fred in NC
>Thanks for taking the time to write about the different types of chucks. Lots of good information in very little space! It deserves to be saved.
I Second that, But....
>Could you post a picture of the tape chuck. I thinks it's the only one you did not post and I have seen you mention it before. I visualize myself looking like King Tut before they unwrapped him and my bowl flying off into the distance. Tape and stretch wrap? Sounds like a disaster waiting to happen. One advantage might be that when you are through, one quick slice with a skew and its off.
Thanks for posting all the pictures, they were great.
Re: Dear Mr. Lucas .
Ron in Drums PA
>Great work John,
Can we save this in the WC article section for easy access?
Re: I Second that, But....
>Barry
Sorry about that I only looked at the first couple to make sure they were posting. I'll do it tonight. I used a tape chuck for many years and never lost one. Since my early useage many people have sent in tips that have improved this method, such as using stretch wrap and/or straping trape over blue painter tape. Anyway I'll post a photo a better description.
I apologize for not having better shots but I've used up almost all my bowl blanks and had to search for things to put in the chucks.
Fast way to get it off...
Stuart Johnson
>"One advantage might be that when you are through, one quick slice with a skew and its off."
Another way to get it off fast is to reach down and turn off the vaccum pump instead of the lathe. This will also wake you up between heart beats.
THANKS JOHN
>John
THANKS A LOT for the above info. The different way you mount bowls or platters taught me a lot.
Again THANKS
