New WoodChat!
HOW WHITE IS HOLLY ?
Jim King
>I am looking for a wood that is as white as Holly. The big problem is that I have never had a piece of Holly in my hands. The two boards on top in the photo are almost white but do have a tint of light cream. Can anyone tell me if I am close or is Holly actually "snow" white ? Thanks for any help.
Re: HOW WHITE IS HOLLY ?
>Jim
Holly is usually very white when fresh cut or Kiln dried but often has some cream or even greenish color if it sits for very long before drying. The Kiln dried boards I have were high quality and are almost completely white, well actually kind of an warm white. The green holly I cut will only stay white if I turn it thin and let it dry immediately. If it sits for even a week it will start getting stain that is blue or green and some cream color in some of the parts.
Jim King
>John: Sounds like simalar properties except this turns whiter with time. It appears to have a high sugar content as mold grows well on it if not treated immediatly. This is harder than oak and most pieces have fiddleback so they are a bit tough to turn.
>Jim
It sounds like really great wood whatever it is. Holly is quite hard and turns with a beautiful finish. I love making ornament finials from it because it's also very tough.
Brad Vietje
Brad Vietje
>John,
I'd like to know a little more ... I make a lot of hollow ornaments, and bought some KD Holly with hopes of making white finials. So far I've only tried it once, but it seemed somewhat rubbery, and inclined to bend ... I ought to try a few more, but please do pass on any words of wisdom you have. Do you put tension on it with a modified live center , or turn between centers via usual compression ?
Safe Spinning,
Brad Vietje
Thetford, VT
Mark Kauder, Phenix City, AL
>Jim,
As you may know, I do mostly Segmented Turning, and as such, the wood I use is used more for it's color than anything else. Holly tends to be expensive, when you can find it, but more than than, it is soft, which can be a problem when you are turning/sanding it along with something dense and hard like Bloodwood.
Are you importing this wood? If so, who/where? I would be interested in trying it.
Mark
Arch
>Jim,
They each know a lot about wood for turning and I thought for sure the Ruths, Molly, Andi or Jen. would jump in and explain about off white, snow white, sugar white, warm white, cool white, bright white, pale white, but never plain white. My wife tried and failed to make me understand. :)
Arch
Russ Fairfield
>At something like $32 a board foot for kiln dried "white" Holly, if I can get it at all, even Birch is white enough for me.
>I hear ya, Russ. I am using Soft Maple.
Now if I can just find a really BLACK wood that is in the $$$$$ a bf range, life would be good.
Has anyone ever tried putting Black Walnut in a vacuum, and then introducing the Vinegar/Iron solution? That black is good enough for me, but it is only microns thick.
Mark
