We value your privacy.
Does anyone know if carnuba wax is an OK first finish for a salad bowl? I've got a maple bowl that I finished with mineral oil and then carnuba wax. I've got a friend who wants the bowl to use as a wet food safe bowl and I am not sure about the carnuba wax.
I figure wax is wax, but I thought someone here might know for sure.
>I forgot - certain candies use a carnuba or carnuba blend coating to prevent them from sticking together - and also so they won't shed dyes and colors in the hands.
>.....as is shellac and jelly wax and varnish and lacquer and mineral oil and sunflower oil and citrus oil and safflower oil and sesame oil and every cured finish I know. I suppose allergens like walnut and peanut oil and as a stretch, an allergenic timber with no finish might be worth considering, but if the finish is well cured and the bowl isn't eaten with the salad, the risk is more in the worry than in the bowl. Anyway, the final finish is usually oil & vinegar rubbed down with garlic.:)
The customer might better worry about who handled the spices, salad greens or fruit in its long journey from field to table and if gentle rinsing removes all the pathogens that hitch-hiked along the way or live on the multi-use chopping block.
More to the point might be to ask what finishes can be made safe for the turner that can't be made safe for the consumer? Just in case, I add the obligatory 'YMMV', :)
I'm used to carnuba beiung used for pretty glossy finishes, though that may not be what you have in mind in this case...
In general, I wouldn't put a glossy finish on any bowl that was going to be handled and/or used a lot -- especially for wet salads, etc... This may not always be true, but in my experience (excepting marine spar varnish) gloss + water = dull. My feeling is that it will look pretty dull and blotchy after a few uses, and the recipient or customer will want to know how to "fix" it. I'd suggest either a dull finish like oil & beeswax, or a number of soakings with Urethane Oil, or one of the Danish oils, with steel wool or abrasive nylon pads between and after to get a softer look.
If you need glossy, maybe something like a hard polyurethane -- just isn't my favorite look for a functional bowl. I tend to use gloss finishes only for decorative pieces.
