New WoodChat!
work shop cooling
work shop cooling
work shop cooling
Bob Tabor
>Does any one use a evaporative cooler to cool their shop or turning area? Or would that create to much moisture in the air for the wood or the lathe and tools? All a fan does is move the hot air around but with the fan behind me it helps with the dust.
Re: work shop cooling
Les Robison
>I have a swamp cooler in my shop that is rated at 5000 cfm. The shop is 14x36 and it cools it very nicely. I don't have any rust problem with the lathe, bandsaw, or tools. It also helps to maintain a level of moisture in the wood while they are waiting their turn for the lathe. I live in a dry area, Bakersfield, Ca. If you live in a humid area, you won't get much benefit from a cooler.
Les
Don Henthorn
>Depends on where you are. Here in central Texas a swamp cooler is useless. The humidity is so high there is little evaporation taking place. In New Mexico it worked like a champ in Albuquerque and Farmington where I lived for a while.
