We value your privacy.
>After reading the *what next* thread below, I have to ask -- does anyone ever try to turn larger than 12 inches on the jet 1236 by rotating the headstock?
I'm wanting to turn a 14 inch diameter 8/4 poplar seat for Mike Dunbar's Windsor Stool and had assumed I could do this on my 1236. Am I destined to break the tool rest extension? Are there any other mishaps waiting to catch me?
You'll probably break the stock extender device thingie. I've never tried mine, as I want to keep in shape for appearence at resale (soon!). You can get away with outboard turning if it is just a 14" platter/seat, but I'd use a floor stand as a tool rest. Not being the one to advocate "cavalier" practices on power equipment, I'll just say that I've used steel pipe with a 1 - 1.25" I.D. cut to the appropriate length and inserted into plywood/2x4 frame. It is an exciting (not the good kind) and workable solution...Not one I'll willingly try again.
It had crossed my mind that I might put a support post directly under the point where the tool rest enters the extender -- kind of a mono-pod setup. No quick revelation how I'd attach it and keep it out of the way of the turning (and the turner).
>If you do other kinds of woodworking in your shop, you might have an infeed/outfeed roller stand for feeding sheetgoods through your TS, etc. If it's sturdy, it will work as a toolrest for table tops, platters, etc.
>I had a cheapie that looked like a Jet 1236. I did a platter that was at least 14". I think I rotated the headstock such that the platter was turning on the opposite side of the bed and this made supporting the tool rest a lot easier. I may be wrong but I don't think I needed that goofy toolrest extension.
When it comes to pushing the limits of a 1236 I AM a pessimist -- I'm not convinced the machine works well WITHIN its limits, much less beyond them, and I'm getting real sick of mine...
That said, I think you CAN do this safely on the 1236, but I would NOT use that stooooopid and dangerous trolling weight* included with the lathe as a banjo extension. If you rotate the head just right, you should be able to reach it pretty well with the standard banjo and the 12" tool rest. You can also lock it down a little past 90 degrees (no detent there), and move the banjo and toolrest to the short outboard bed section. This will only work up to about 14" in diameter -- bigger than that and you can't get the rest in front of it without the extension arm, which I truly believe to be a health hazzard.
Safe spinning,
Brad Vietje
Thetford, VT
* Can also be used as a window weight if you have old double-hung windows ...
>I turned a 14" chip bowl on mine. I was able to do most of it without the extension. Watch when you do use the extension as it vibrates pretty bad. Definitely use light cuts cause I think it will land on your foot if you get a nasty catch.
I need to turn another one and I'm thinking of propping up the rest with a piece of oak 2x2 to see if that would help.
