New WoodChat!
Rockwell/Delta 12" lathes
Kudzu
>I have been looking at the Rockwell/Delta lathes for a while now. They seem to be a good choice for me. But I am curious to if there is any reaon you couldn't add riser blocks to give them an 18" swing? Are the bearing good enough to handle a large block of wood like that?
Replacing bearing or even rebuilding the lathe is not a problem for me.
I have also looked at the Powermatic 90. That seems to be a heavier built lathe. But I am only judging by the photos. I have not actually seem one. They are not nearly as common and I hear that they are harder to find parts for too.
Re: Rockwell/Delta 12" lathes
>I turned on one in a class taught by Nick Cook. Pretty beefy. I don't know about the riser blocks. He did a a VS upgraded motor on it. It acted up (electronics problems) once in a while. It was pretty steady even with a Talon chuck and 2-3 lbs of wood.
