New WoodChat!
McNaughton Center Saver
vicmarc.fan
>What a wonderful place this is. Thank you guys for all the tips on how to use the center saver. On my third block of wood I got 4 cores out that I can make into bowls. The other blocks made little blanks OK but I turned out the bottoms of the big core. Most of the cores looked like cones not bowl blankes. I found out my main problem was the blades tended to hang up in the support assembly. The tip to use PAM spray on the blade worked for me.
Ron
