New WoodChat!
Veritas - Innovation in Tools
Afzelia Bowl
Afzelia Bowl
Afzelia Bowl
Gary Ljostad
>Description: 6.5"x2". Afzelia bowl with wide under cut rim. Burned rim design made with 1" copper plumbing fitting heated with blow torch and used like a branding iron. Finish is Mahoneys Walnut Oil, buffed, and waxed. Burnt inner and outer rims were friction burned using a thin piece of ebony and high speeed. All comments welcome.
Re: Afzelia Bowl
Re: Afzelia Bowl
Jennifer@Indy.USA
>Gary, this is really awesome! I love the design of the bowl and the burning is fantstic. What a great idea for a burning tool! Did you map it out to make sure that all the rings would be evenly spaced, or did you just go for it. Sometimes I find that the layout is somewhat difficult on stuff like this.
Beautiful piece!
Jennifer
Re: Afzelia Bowl
Re: Afzelia Bowl
Mike Schwing from Md.
>Now there's some inspiration for ya! Your work never ceases to impress Gary. Very creative, wonderfully executed.
Re: Afzelia Bowl
Re: Afzelia Bowl
pfduffy
>Gary, very beautiful bowl. Wonderous end result. Fantastic execution. Phil
Re: Afzelia Bowl
Re: Afzelia Bowl
Gary Ljostad
>Jennifer, I did a rough layout just to see if it would work out. The nice thing about the plumbing fittings, is they come in verious sizes from 1/2"-2" in 1/4" incriments. So I could have gone to the next bigger or smaller size to get it to fit.
Re: Afzelia Bowl
Re: Afzelia Bowl
Bob R WestMac Turning
>Great work. Would be hard to get a more creative piece.
Somthing for a newbe to shoot for.
Bob R WestMacTurning
Re: Afzelia Bowl
Keith Tompkins
Re: Afzelia Bowl
Keith Tompkins
>Hi GAry, did you use the indexing on the lathe to space the rings? this is a great idea, there are almost endless possiblities! You may be on to something here!!!!!!! NICE job, my friend.
Re: Afzelia Bowl
Re: Afzelia Bowl
GaryG in MD
>Great ideas and execution. Lots of innovation there. ...GaryG
Re: Afzelia Bowl
Re: Afzelia Bowl
Ben Aragon
>Very nice work, I like the foot detail.
Re: Afzelia Bowl
Re: Afzelia Bowl
Gary Ljostad
>Hi Keith. The burning was done off the lathe. I made a articulated carving vice that will accept my chuck. I used a devider to do a rough layout. I new it would be very close by figuring the circumference of the bowl at the mid point of the rim.
Re: Afzelia Bowl
Re: Afzelia Bowl
Craig Daymon
>Very, very nice job Gary. VEry cool idea and executed extremely well. I'm thinking it might have come out a little odd if you hadn't gone with such a uniform pattern, but you did it great.
I'll have to pull up a drawing program and make some circles and see what kind of designs I can come up with.
-Craig
(Oh yeah, and the shape of the bowl and finish are outstanding as well. It's hard typing with 2 thumbs way up!)
Re: Afzelia Bowl
Niiice!
Dominic Greco in Richboro, PA
Gary,
Well done! I really love the shape. The scorched/burned accents really work well on this bowl.
I just read through the other posts here and found out how you managed to burn those circles so consistently. Your use of copper pipe as a brand was inspired! It opens up a whole area of possibilities. Copper is so soft, you could use a Dremel and "carve" you own design for a brand.
See ya around,
Dominic
