New WoodChat!
Goose Neck for laser Pointer?
Ron in Drums PA
>I've been looking around for a goose neck to hold a laser pointer for a hollowing rig and I have come up short.
Does anybody know where I can get one?
Re: Goose Neck for laser Pointer?
Ed Thomas, Leaside (Toronto) Ontario
>Do a search on McMaster-Carr for gooseneck. I found some there but can't link to the page. Alternately, I suppose you could turn the segments and make your own.
>Ron
MSC has sort of a goose neck available. Actually any of the machine tool catalogs have these. It is a series of flexible joints used to hold things in the metal working industry. They work really well and you can get them in different lengths. They look like a series of beads strung together. I don't know what they are called but will look them up tonight if no one else comes through before I get off work.
Thanks John
Ron in Drums PA
>I tried doing a search on MSC and couldn't find it. Do you know what it is called?
Thanks Ed
Ron in Drums PA
Brian McKearney
Re: Thanks John
Brian McKearney
>Might be called "Loc-Line"? See http://www.loc-line.com/. I bought some larger stuff for dust collection at the lathe, but they also make really small parts (small enough to be used as the skeleton of poseable dolls) that might be what John is referring to and may do the trick.
Re: Goose Neck for laser Pointer? *LINK*
Gerry in Maryland
>Hey Ron
Ya suppose somthing like this would work?
Gerry
Grizzly/mag holder
Mark Kauder, Phenix CIty, AL
>Go to Kevin Neeley's website and look at the one he made. I made one, and it works great.
Mark
Ron in Drums PA
>Thanks Mark, what is his web address?
Ron in Drums PA
>Looks Good!
Any thoughts on how to attach it to the shaft of the tool?
>Ron
Brian was right. I found the Loc-line modular coolant components in my Enco catalog. www.use-enco.com or 1-800-873-3626 Loc-line 1/4" hose kit (13" with fittings) part no 505-2087 $8.10
Mark Kauder. Phenix City, AL
>sorry Ron, I thought I put it in the message.
WWW.turnedwood.com
Mark
>here is where I got mine.
mark
http://www.modularhose.com/
>Ron,
For any of these goose necks, you can get a "Beam Clamp" and Home Depot or Lowes, etc in the electrical department. Once you look at, you will figure it out.
Mark
Thanks!!!!
Ron in Drums PA
>Just ordered everything I need!
