New WoodChat!
chainsaw rim sprocket ??
e
>on a husky rancher 55, anyone know how to get the clutch assembly off in order to replace the rim sprocket???
or where a service manual might be found?
my old chevy vega was so much easier!
Re: chainsaw rim sprocket ??
Ace Foster in Ben Lomond 95005
>I'll see if I can find something at work tomorrow. We service Huskies (tho' I don't do it personally.)
Ace
e
>thanks ace ... greatly appreciate it!
>Slower than I intended getting back to you here, but...
Two things: you need to block the piston so the crank won't turn. There's a plastic tool for this, but a piece of dowel in the plug hole works also. Two, the assembly screws off the end of the crank; it's left handed, so it feels backwards. You may have to gin up some sort of spanner to get it unscrewed.
HTH
Ace
e
>thanks!! -- especially about the left handed disassembly.
