New WoodChat!
mesquite (stained hands?)
ken chase
>After working my first mesquite bowl I noted my hands were stained a dark gray color, mostly the left. The stain would not come off with boraxo soap or hand cleaner. Is this a common problem? What should I do to remove the stain? I'm thinking I should wear gloves today.
suggestions will be appreciated
Thanks
Re: mesquite (stained hands?)
Stuart Johnson
>Cut a lemon in half and rub the stain. This works for Walnut so I think it would work for Mesquite.
Jim King
>Pure clorox works on the stains here.
Re: mesquite (stained hands?) *LINK*
Paul Porter in Phoenix, AZ
>Ken,
That stain is from the tannic acid in the wood and mesquite has a high tannin content. It happens when the moisture in the wood and on your hands touch the steel of your gouge. Lemon juice will remove the stain.
my web site
Jerry Whitaker
>Lemon or Lime juice will make the stain disappear instantly like magic for Mesquite also.
Stain all gone Thanks All!
ken chase
>The lemon worked like a charm. I learn something every time I log on this amazing board. Thanks
Re: Stain all gone Thanks All!
GaryG in MD
>You can also use this effect to your benefit. Soak a piece of steel wool in vinegar overnight and then use the vinegar as a "magic" stain to darken tannic woods (like oak). ...Gary
ken chase
>Thanks for the tip Gary. I'm picking up some oak from a friend later this month. Never turned it before.
