New WoodChat!
Indexer - finally!
Indexer - finally!
Indexer - finally!
Fred in NC
>Finally got a chance to get back in my shop!
A machinist friend of mine made the indexing plate. It fits any lathe with a 1" spindle, such as the Jet Mini, Delta Midi, and several of the 12" lathes.
It is made from industrial cabinet aluminum, black on both sides, 6" diameter with 24 holes (15� apart) made directly in a precision rotary table. It has a 1" hole.
The plate fits directly on the spindle, with a plastic washer behind the plate. It can be held in place with a 1"-8 nut, as seen in the pic, or with a chuck. The plate is big enough to be used with most chucks. When using the nut a pen mandrel can be used in the spindle.
The pin that fits in the holes is slightly tapered (5�) for a tight fit in the holes.
The rest of the setup, the indexing arm, base that holds the arm, etc. were made in my shop with common tools. Excepting for the nuts and bolts it was all scrap.
This design does not require any alterations to the lathe; no holes need to be drilled. The base sits out of the way, it does not have to be removed each time it is used. The arm is held with a 1/4" bolt with washers and wingnut, so it is very easy to remove.
I will be making a jig to hold a Dremel or laminate router to go with it. It will allow drilling around the workpiece, and longitudinal routing. For example I will be able to make a six sided spindle. Again my design for this jig will be such that it can be easily made with common tools and materials.
Thanks for looking.
Re: Indexer - finally!
Larry in Lima
>If you get something like this set up for sale, let me know. I'd be interested, and it looks rock solid from what I can see. Thanks for the post and pic. Larry
Fred in NC
>Thanks Larry!
As stated in my post, I figured this so it would be kind of inexpensive. I am working on a set of plans. The plate itself is the hard part to make accurately, the rest you can make easily in your shop.
My plan is to offer the plate, and possibly the taper pin and nut that goes with it, along with a set of plans. I am working on the jig for the drilling and routing because I want to be able to include those plans too.
I will figure out the cost, and post it soon.
MP Wall
>Sounds like a business plan to me. That looks like a damn why couldn't I figure that out kind of thing. Great looking and probably works as great as well. You might consider offering with a 1 1/4 hole for pm3520's that are older and have no facility for indexing. MP Wall
Eduardo Sarmiento Hall-Lima Peru
>real nice Ill make me one thank for sharing
Fred in NC
>Glad you like it! Saludos desde NC USA
Craig Daymon
>I'm working on a JET mini now, but I think a 3520 is in my future, so I'm interested in both (unless the rumored 3520B already has it).
-Craig
