New WoodChat!
Vacuum Chuck safety
Vacuum Chuck safety
Vacuum Chuck safety
Philip Duffy
>Buddy of mine, a brilliant engineer, developed a vacuum system that is a bit different and definately safer than those I have seen. It is a joy to use.
He has his pump pulling a vacuum off a purged propane tank, with the tank connected to the headstock rotator. All the pump has to do is maintain a safe vacuum in the tank. Propane tanks are more than capable of resisting the atmospheric pressure, even with 30in of vacuum in the tank. The guage sits on top of the tank so it is in plain sight. When the pressure drops, as in an elec. failure, there is plenty of time to take control of the workpiece and remove it from the lathe when the vacuum releases. Thanks, Bob Wilkes, MIT '55&56!
Re: Vacuum Chuck safety
Robert Cox
>An accumulator!
Not a bad idea at all.
How Big
Wayne Cooper Charlotte NC
>Thanks for an excellent idea. How big of a propane tank did he use. 20#, #40 or 100#??
Wayne
Walter Ahlgrim
>Just how does one safely purge a propane tank?
