New WoodChat!
Sorby Sander....HELP
Dennis Taylor
>I got a Sorby sander awhile ago, and can't seem to make it sand...I have oiled the bearning area, and have tried to adjust the angle of the head to the spinning wood, I am sure it is a me problem and not an it...help!..Dennis
Re: Sorby Sander....HELP
RevDoug
>If you are talking about the Sorby passive sander then a few questions come to mind.
1) Are you presenting less than 1/2 the sanding head to the wood?
2) Is your presentation at about 9:00 - 9:30? Or, 3:00 - 3:30?
3) It may seem like a really silly question, but is the lathe running?
4) Is is safe to assume that the head does infact turn freely?
Feel free to email direct if you have further questions.
Turn 'em round,
RevDoug
Dennis Taylor
>The lathe is running at slow speed, about 500 rpm's or less...
I am presenting the tool at about 7:00 ...and the tool head does move freely on the shaft
I am applying only the edge of the sanding wheel to the wood, the majority of the wheel/sanding disc does not contact the wood
tried it again this morning with same results, seems like I am just not getting the right spot on the passive sander to make it spin..Dennis
Re: Sorby Sander....HELP *LINK*
JHS
>Go to the Link below and select the Instuctions in the navigation pane. Sorby has a PDF with operating instructions.
http://tinyurl.com/cngnu
