New WoodChat!
aluminum face plate?
ken chase
>Are aluminum faceplates good? Or is it best to
stay with steel.
Thanks
Re: aluminum face plate?
Chris Wright
>I have used the aluminum faceplates that both Don Pencil and Steve Mink sell for about 3 years now. They work just as well as my steel ones and in fact are easier to true the faces if necessary.
Carole in VA
>I use the Don Pencil ones, BUT it is my understanding that if you are going to mount a heavy or very off balance piece, you should use steel. I don't have a lathe that can handle heavy pieces so I can't speak from experience, but it makes sense since aluminum is relatively soft compared to steel.
John Trant (Baltimore/DC area)
>Steel (e.g. BestWoodTools) is better for large, out-of-balanced pieces but aluminum is perfectly fine for most work we do.
John
Don Pencil
Don Pencil
>Ken,
Whatever a 2" steel faceplate can handle, so can an aluminum faceplate of the same size. That applies to 2.5", 3", 3.5", and 4". If one needed a faceplate to turn a 24"-36" out of balance blank then steel would certainly be a must (mainly because the cost of making such a faceplate would be prohibitive).
I would be more concerned (blanks over 16") with how many and how large the screws are for the faceplate.
Anything I can turn on my 16" x 42" lathe with it's 1 1/4" x 8tpi spindle a 3.5" aluminum faceplate will handle. For small work, 8" and under, I generally use a 2.5" faceplate.
Keep up the good work.
Don
Steve Worcester
>"Steel (e.g. BestWoodTools) is better for large, out-of-balanced pieces but aluminum is perfectly fine for most work we do. "
Best Wood Tools faceplates are aluminum.
Steve Worcester
www.turningwood.com
