New WoodChat!
Veritas - Innovation in Tools
Platter drying experiment 1 (Very LONG, sorry)
Gary Evans, Tallassee, TN
>Hi all,
The camphor platter that I turned this past weekend is beginning to warp a bit. I expected it to happen because the blank was quite green when I turned it. But, since this was my first time on the lathe in several months, I wasn't particularly interested in roughing out something to finish later. I wanted to MAKE something! I turned a 1/16" to 1/4" taper, edge to bottom, on the first go-round.
I have been studying the somewhat esoteric science(or is it art?) of wood-drying for a number of years now and thought that I would see if I could deal with the warp as the platter dries.
Here are a couple of pictures of my game plan as the platter continues to dry.
My experiment is to clamp the platter flat and dry it SLOWLY and see what happens. The first picture shows the 2 pieces of 20" x 20" x 3/4" Oak plywood and 4 handiclamps that I am using for my press. The platter had warped more than 1/4 inch from it's original 1 1/2" height, making the space between the plywood sheets somewhat greater than 1 3/4". At present I have it clamped at 1 5/8", measured at each clamp. The blue plastic that I am using for protection of the edge and the bottom is a very open-pored sheeting. I'm not sure what it's intended use was, but it works great for cushioning jam chucks as well as making sanding pads. Anyway, it should allow some small amount of air circulation at the edge and the base of the platter.
The next evolution will be vent holes in the top and bottom sheets of plywood to allow more airflow to the both sides of the platter.
I am blessed to have a creek running right behind my shop (about 5' away.) Since the air in the shop is un-tempered, the Relative Humidity stays pretty high. I should be able to dry the platter very slowly, gradually tightening the clamps till I get it back to the original 1 1/2" height. After several weeks in the shop, I'll gradually introduce it to drier air till I get it dry enough to live in the house. This one is a present for the LOML.
It was interesting to see the behavior of the warp since I turned it this weekend. It stayed pretty flat in my relatively humid shop until Tuesday morning, when I took it with me so that I could show it at our club meeting on Tuesday night.
I am currently working with an engineer friend in his shop, so naturally I took it in to show it off on Tuesday morning. His shop is air-conditioned, as well as having a fan to move the air around. By midday, the platter had picked up the 1/4"+ of warp.
I wrapped it back up in plastic bags once I saw that it was warping. By Tuesday night at the meeting it had relaxed a bit. I doubt if it had more than 1/8" of warp. Tonight I clamped it up and we'll see what happens. I may have to make an unscheduled trip to FL for more camphor if this doesn't work out. 8^]
The original link with a picture of the platter is:
http://www.woodcentral.com/cgi-bin/turning.pl?read=71562
Has anyone else tried this? I would welcome comments and advise. Sorry to be so long-winded, but sometimes a story has to tell itself. You lose too much when you try to edit.
Thanks,
Gary
Re: Platter drying experiment 1 (Very LONG, sorry)
Re: Pic #2
>In this picture you should be able to see the side of the platter, along with the plastic stuff that is cushioning the edge and the bottom.
Gary
jeff jilg
>Gary - I never tried that, it looks like an interesting experiment. Longterm I would be concerned that the finished piece might try to revert to its internally desired warped shape. Wouldn't the internal stresses react over a few seasons to warp the piece after it contact normal humidity? So you might end up with a round shape now, but then in 2 or 3 seasons it could warp.
JHS
>That's what happened to me with a large walnut platter
Hawaii Turner
>Gary,
I wonder that if it is restrained from moving by your clamping, will it split instead?
Aloha, Doug
Mike Schwing from Md.
>Applause for your experimentation! I'll be very interested to see how this goes. Here's what I suspect: You will succeed in drying this with minimal distortion. BUT, a little seasonal moisture will cause it to begin to warp as it had intended to in the first place, and it might even crack. You're going to have a whole lot of tension captured in that platter when it dries, and I wouldn't be suprised if even something as simple as wetting it down to raise the grain causes a visible distortion.
Please keep us posted.
Ruth Niles
>Mike,
Would it help eliminate possible cracking if Gary coated the turning with an oil?
Someone (might have been Russ) told me when you final-turn green wood, it helps the wood adjust to the moisture loss. I have a really hard time rough turning only because I want it NOW, and non of my bowls have cracked after drying and I'm attributing it to the oil. What do you thing?
>Good point, Jeff,
This experiment is along the same lines as applying weight to the top of a stack of lumber to keep the upper layers from warping.
I'm hoping that the relative thinness of the platter will help the stresses to even out over time. I have nothing but time for this. If I have to keep it pinned down for a couple of seasons, I can do it.
Thanks,
Gary
>You may be correct, Doug,
I am hoping that the thinness of the platter will help to cut down the magnitude of the drying stresses that develop. This one is getting the slow-hand approach. That should allow the wood to gain strength faster than the stresses build.
Thanks,
Gary
>Thanks, Mike,
I'm going to pull it out of the clamp this weekend and drill those vent holes that I talked about. I expect it will be a number of months before it comes back out. I'll let you know in a year or so how it's doing.
Gary
>Good experiment. I have wondered about trying to keep things round by constraining green bowls while drying, perhaps by forcing them into a cylinder or cone, perhaps even steaming first. Green wood is relatively soft and pliable, just like steamed wood. Heat and steam a thin piece of wood and bend it and when it dries it stays bent.
Wood seems to get so much harder when "cured" I wonder if there is some chemical change going on such that later seasonal movement will not completely undo. If the wood is thin enough, it may even dry and harden without cracking.
JKJ in East TN
>Hi Ruth,
I don't do much green-to-finish turning these days, but when I did I had very good success liberally coating the turning with oil (I used walnut oil but only because I had it on hand), and then putting the turning in paper grocery bags for a couple of weeks. In fact, I recall even having success at keeping pith from cracking with this method. I don't really enjoy that kind of turning so I don't do it much anymore but if I did I'd employ that method again.
I don't have any science to back it up, but as to helping with this particular experiment, my hunch is it won't make much of a difference.
>Hi Ruth,
This one has two coats of Velvit Oil, and I'll probably put another one on when I take it out this weekend. The oil should also help with my plan to slow down the drying rate. This helps to minimize the stresses that might otherwise create cracks.
The Relative Humidity, temperature and air movement determine the drying rate. The drying rate determines the stresses that build in the wood. If the stress exceeds the strength of the wood, then the wood starts to crack.
Fortunately, wood gets stronger as it gets drier, so the trick is to maintain a drying rate where the strength curve is slightly ahead of the stress curve. Since I haven't checked the moisture content of this wood, I'm sort of flying blind on this one (that's where the art comes in,) but the high RH in my shop is my best friend in this situation. It's hell on tools, but great for drying wood slowly.
Otherwise, I would have to devise a way to create a high RH until the wood gets down to 25% MC or so, at which point the strength is close to maximum.
Gary
>John,
I'm expecting to see the platter act like the steamed wood you mention. I expect, over time, that it will take a "set" that will keep it relatively flat from that point on.
If you couldn't force wood into the shape you want, then green-wood bending, as well as restraining stickered wood with weights, would not work very well.
By the way, I appreciate you allowing me the conceit of calling this an experiment. Since I don't have a control involved, and my sample size is quite limited, it isn't very scientific. With your background, I thought you might bring that up. 8^]
Gary
Carol Reed - Strawberry, AZ
>A suggestion, if I may, Gary.
Unless you have a plethora of clamps and don't need these for the several months you want to run this experiement, you might drill bolt holes through your plywood, install long bolts, nuts and washers. Easy to tweak the plywood for even space all the way around and frees up your clamps.
Just a thought.
Re: Restraint while drying
Russ Fairfield
>Yes, restraint while drying will help. It works for drying lumber and veneer, and it will work for your platter or bowl. Several things that might help, and some suggestions for further experimentation.
Be careful to not use too much weight. This is a case where, if a little is good, more is not better.
Like any other piece of wood that is being dried, it is important that there be no moisture gradient across the piece of wood across the piece while it is drying. In this case that means that the exposed rim doesn't dry faster than the rest of the piece. Being thin will help, but you may need more than that. You can do this by keeping the rim moist with a spray bottle of water, and letting it dry after the rest of the piece has lost some water. I would suggest drilling holes in the board used for a weight. This will let out the moisture from under the weight.
Several layers of newspaper between the wood and the weight will be helpful for keeping the moisture equal. Change the newspaper when it gets damp.
Keeping the rim damp also helps keep a bowl rim from cracking while it is drying. Drying a bowl upside down with the rim on a damp towel will keep the rim from drying faster than the rest of the wood. Keep the towel damp until the rest of the bowl has started to dry.
Bowls respond very well to band clamps around them, particularly if they are being dried in an enclosure with a controlled environment such as a kiln or a drying room.
We can also prevent some of the cracking that always happens across the foot of a rough turned bowl by mounting the green wood on a face-plate that will not be removed until after the bowl has been dried, turned the 2nd time, and finished. A hose-clamp can be used around a chucking spigot to do the same thing.
Re: Platter drying experiment 1 (Very LONG, sorry) *LINK*
Well, I imagined there were plenty of control samples around with a variety of woods and shapes - nearly everything green I turn warps and/or goes out of round regardless of whether it is flat or deep. Even Tuesday evening, you could see the platter was warped and I doubt it would ever flatten out by iteslf! If you are successful in keeping it flat, I think it is an excellent experiment even without controls.
I've also read of people microwaving bowls, and while hot and steamy, warp them significantly for an extreme effect. Your "unwarping" is similar. Of course it would be far simpler to make something "precisely" unround and unflat rather than precisely round and flat! For your platter, I suspect you could easily control the flatness but not any oval shape.
Another data point - read about the guys who turn the amazing wooden hats - they build bending jigs made of sticks, rubber bands, springs, etc to shape the hat exactly as desired. Once shaped, it seems to stay. Although these hats are far more complex than a platter, seems this is technique, not experiment.
JKJ in East TN
http://www.woodhat.com/workshops.asp
newspaper
>and the weight will be helpful...
I've had the ink from certain newspapers come off on my hands. Seems like those papers might stain wood, especially damp wood.
For those who don't know, in many places you can get free rolls of unprinted newspaper for the asking. I get end rolls from the local paper and use them for a variety of purposes. No ink to deal with and you can wrap things with very long pieces if necessary. Ocassionally they even have end rolls of white bond paper.
JKJ in East TN
Barry N. Turner
>Since you are restraining the blank from movement while it dries, wouldn't it be more prone to cracking, since it won't be able to move and by so-soing relieve it's internal stresses?
>Hi Carol,
The bolts were the original plan, but I discovered that I didn't have any long enough. Saturday's evolution will include bolts.
Thanks,
Gary
>Hi Barry,
My thinking is that by controlling the drying rate, I will control those stresses below the level at which the wood will crack. Since the wood strengthens as it dries, the drying rate can increase as the platter gets drier.
I like Russ's suggestion about keeping the rim moist. I am going to try to incorporate that in my plan.
Thanks,
Gary
>It seems to me that the clamps or bolts will loosen over time as the bowl drys and shrinks. Perhaps you are monitoring this closely and manually keeping the bolts tight? Why not use some springs? You can get an assortment of springs and find ones that apply enough pressure. Also, not much chance of over tightening them.
>Hi Barry,
If this pans out, I may rig up a press with springs for a future green platter experiment. With this one, I wanted to be able to control the pressure as the platter dries. I was afraid to try to straighten it the whole 1/4" at one go. After I drill the vent holes this weekend, and install the bolts, I'll try to take it the rest of the way to flat.
By the way, how did you come out with your solar lumber drier?
Gary
