New WoodChat!
About 80gr. gouges and other sandpaper
Hawaii Turner
>Aloha, Everyone
I have nothing to do with the company (I wish that I owned some stock in it) but I, and most members of our club, have used MIRKA sandpaper for about 10 years. IMO, I feel that it is the best cutting and longest lasting paper that I have ever used. Well, at our meeting this past Sat. the dealer shows up with their new product. It is called ABRANET and is a ceramic impregnated onto hook and loop discs. I have only used it a little yesterday, and can't give it my personal endorsement yet, but one of our members who turns huge Norfolk Pine vessels, just raved about it. He did a demo on a roughed out Calabash of a fairly hard wood, we call it Chocolate Albizia, but he started with 180gr on a rather rough turned bowl about 16" in dia. and in 2 or 3 passes, it was all cleaned up. Personally, I would have re-turned the surface better before starting with 100 or so grit of regular sandpaper.They said that you can start with a finer grit, and don't have to use as many grits to do the job.Also, is supposed to last a lot longer, after all, it is ceramic. Time will tell.I thought that I would pass this on in the hope that it might help someone.
Aloha
Doug Leite
Has any
Re: About 80gr. gouges and other sandpaper
georgetroy
>I must confess, I use sandpaper. Most of the time it is the Vic Wood inertia holder. I would like the link or e-mail on the paper you mentioned. Thanks George
Re: About 80gr. gouges and other sandpaper *LINK*
Hawaii Turner
>George,
Here is a link to MIRKA
http://www.mirkausa.com/products/brands/abranet.htm
I am a little confused an the dealer tols me it was ceramic and the webpage says aluminum oxide. Gotta look into it.
Aloha, Doug
Mirka USA-Abranet
Terry Quiram, Roanoke Illinois
>Doug
I have been using Abra-net for about 6 months and I love it. It does indeed last an extremely long time. I use 80 through 600. However the last sanding I give a bowl is with conventional paper.
Terry
Hawaii Turner
>Hi Terry
1)why do you final sand with regular paper?
2)what grit do you finish with?
3)have you ever tried Abralon?
always glad to explore others methods
Aloha, Doug
Dave Anderson Chester, NH
>The bit about being ceramic sounds like marketing hype to me. Aluminum oxide is by definition a ceramic as are some of the related materials like boron nitride. Much depends on how the material is processed and coated.
