New WoodChat!
Bent McNaughton Blades
DaveL
>I finally got to use my McNaughton system and during the first bowl the medium blade bent and twisted. This was the first bowl so i was inserting the tool very slowly and the lathe was spinning about 350 rpm when the blade twisted in the gate and the blank wedged on the blade. When i pulled the blade out of the blank ii is bent and twisted.
Are the blades really this fragile?
How does everyone keep the blades from bending?
How do you submit a warranty request?
Any suggestions and or comments are appreciated.
Thank You,
Dave
Re: Bent McNaughton Blades
Eduardo Sarmiento Hall-Lima Peru
>Well I went tru the same thing once in the beginning just bend it back and be careful next time make sure is very well in the place and resting against the stop remember HANDLE UP ALWAYS. ED
George Van in WI
>You did not mention the size of the bowl but 350rpm is very slow. The chips will build up and grab the knife if you do not clear them, causing the blank to bind on the blade and possibly bend or pull the blank off the tenon. More speed makes the knife cut smoother and the chips eject easier. On the size bowl I would be using the standard set, medium blade to core I would be 700-800 rpm. When I first started I loosened the drive belt so when there was a jam the belt slipped. Are you frequently backing the knife out to clear the chips?
Did you make a second cut at the beginning to allow the chips to escape?
Have you watched Mike Mahoney�s DVD? If not I would recommend you do so.
Good luck, there is a learning curve.
Greg Jensen
>Send the blade to me and I will have a look.
Greg Jensen
North American Rep for Kelton Tools
7521 Green Valley Drive
Parma, Ohio 44134
440-570-7596
woodspinner/ Bill Hale
>I agree turn up the speed. I too had a problem with twisting until I learned to go slow and a lot of in and out for chip removal.
Straighten them and try again.
This tool does have a gigantic learning curve but it is worth it. I don't think any other has the adaptability to as many core shapes and sizes. Be patient.
Good turning and be safe
Bill in Casa Grande, AZ.
ruth in So. Cal
>Same thing happened to me when I was trying it out at Woodcraft......I went with the woodcut instead.
